Driveshaft Question
Old May 24, 2008 | 09:06 PM
OldskoolRcr's Avatar
Default Driveshaft Question
Have a built 4l60e from Performabuilt, now going to either a 9" or 12 bolt, question is this as for the drive shaft is there going to be a lenght issue? does it need to be shortend or is the stock lenght correct? or what does the lenght jave to be?, I am sure there will be a Ujoint change for the rear. Thanx.
Old May 24, 2008 | 10:43 PM
CW00BlackTA's Avatar
When I went to a 9 bolt I used the stock drive shaft and then an aftermarket with the same length.
Old May 24, 2008 | 11:33 PM
KH504's Avatar
I put a 12 bolt in I used stock drive shaft but I had to have it cut and new u joint put on for 100.00
Old May 25, 2008 | 01:01 AM
Thanx guys, thats what I needed to know. Anyone happen to know the what the lenght would be for a 12 bolt drive shaft? I suppose by measureing center to center on the u joints.
Old May 25, 2008 | 06:25 AM
EPP's Avatar
EPP
http://www.exoticperformanceplus.com....html?item=541
The 12 bolt uses the same length driveshaft as the oem 10 bolt does. The Mosr 9 inch needs a one inch longer driveshaft. Bob
Old May 25, 2008 | 07:45 AM
Thanx Bob, I am going to contact you on Tuesday, we can see about a rearend.
Old May 25, 2008 | 11:09 AM
EPP's Avatar
EPP
Thumbs up
Sounds good, thanks! Bob
Old May 25, 2008 | 01:42 PM
ls2 bait's Avatar
how do u think one of these would hold up to 700rwhp/tq in a six speed car? i have a heavyass chromeoly one now but i need a shorter shaft and wouldnt mind a lighter one at the same time. pm me if there is additional pricing for a shorter unit.
