how much will 4:10s help
.tia
and you
I had stock 3:42's and got 24mpg highway, 18 city .... with the 4.10s I get 23mpg highway and 18 city. As for the tires, where did you come up with that? Any f-bod can smoke the tires regardless of gearing ...
Personally, I find it just as easy to launch with the 4.10's as I did with the 3.42's. I do agree however, that they might be alittle much for the street. Unfortunately, in an M6, they make the "magical third gear" into the "magical fourth gear" ... so you have to wait 10 - 15 mph more for that big punch in power that your used to getting in third gear. On an auto car I would definately put in the 3.73's, as I did in my old auto LT1. Cruising around 70mph had me around 2300 rpms, which allowed for decent gas milage. 4.10s will bring that up to around 25-2600rpms, which will hurt the mpg a decent amount. M6 I still say 3.73's/4.10s are great all around gears.
You even admited yourself that 3:73's are better and more reasonnable.
By the way do u know what is the final drive ratio for an M6 compared to an A4? NO! I didn't think so. Otherwise what I said would make perfect sense to you. :p
Next, if I were you, I would put some more research into your obviously unknowledgable 'calculations'. The 4th gear drive ratio of an A4 is 0.70 ... which, when combined with 3.73 gearing, puts 67mph at exactly 2300rpms, and 70 mph at exactly 2400 rpms. If he got 4.10's, 70 mph would be right around 2600 rpms. So really don't understand where your getting 55 mph as the speed I was driving at that RPM.
So let me make this easy for you...
In an A4 with 3.73's ...
RPM ------- Speed
1900 ------ 56 mph
2100 ------ 61 mph
2300 ------ 67 mph
2500 ------ 73 mph
2700 ------ 79 mph
In an A4 with 4.10's ...
1900 ------ 51 mph
2100 ------ 56 mph
2300 ------ 61 mph
2500 ------ 66 mph
2700 ------ 72 mph
In an M6 with 3.73's ...
1300 ------ 53 mph
1500 ------ 61 mph
1700 ------ 70 mph
1900 ------ 78 mph
2100 ------ 86 mph
In an M6 with 4.10's ...
1500 ------ 56 mph
1700 ------ 63 mph
1900 ------ 71 mph
2100 ------ 78 mph
And if you had spent alittle more time with the hooked on phonics, you would've noticed that I was agreeing with you about the gearing. ...
....I do agree however, that they (4.10's) might be alittle much for the street....On an auto car I would definately put in the 3.73's, as I did in my old auto LT1. Cruising around 70mph had me around 2300 rpms, which allowed for decent gas milage....
Final drive ratio in 6th is lower than 4th in A4 (LIKE you've shown in your numbers).
Your calculator is smoking by the way LOL.
Also, it is good to put # on paper, but did you take tire diameter into consideration?
If you didn't then your calculations are innacurate and those numbers would vary from car to car depending on their car's tire height.
No one knows everything in life and we just voice opinions and should not attack each other. UNless it's BULLIT of course. LOL
Obviously, if you were to change the tire sizes, you would be effectivly changing the gear ratio, but thats a given.
And I agree that we should only attack bullitt. (check out the new sig ...)
