401 rwhp ls1 camaro
401 rwhp ls1 camaro
98 ls1 6 speed camaro 401 rwhp w/381fpt i would like to replace my factory rearend what shoud i go with and how long will my factory rear last if i buy drag ra tires
mods...
vengence racing vrx5 camshaft kit230/232
knooks stainless long tubes w/y pipe with cut outs
ls6 clutch
blue maxx 90 tb ported by vengence
fast 90 mm intake
slp lid
hooker performance mufflers
411 gears with factory rearend
dyno jet tunning
asp pulley belts and bolts
vengence racing built this car i dont no what all they did to it bought the car as it is. i no they left the bottom end stock
mods...
ls6 clutch
fast 90 mm intake
slp lid
dyno jet tunning
It depends on how you drive it. If you go to the track and start dropping it at 4k+ rpm's then its probably not going to last too long. If you do alot of roll racing or get it moving before you whack it it will probably last for forever. It all depends on how you drive it. Some guys run in the 10's, some guys break it with stock power.
A lot of people have broken the 10 bolt powershifting into 2nd gear on the street with regular street tires. With a six speed don't expect it to last.
Here is the rear I recommend. http://www.exoticperformanceplus.com....html?item=145 Bob
