U joint problem? Caps popped off
What causes the caps or driveshaft to shift? How do I fix the u joint? Is there some sort of clip that holds the u joint caps on and in place? Does it need to be fixed or do I just slide the caps back on and bolt it in with the u bolts?
re-read.....sounds like you have the wrong u-joint
Check here to see what type of joint and yoke you have. It involves a little measuring.
I'm guessing I had the wrong ujoint/yolk combo.
The joint caps are 3.62 apart and 1.125 diameter. The caps aren't a perfect glove like fit in the yolk, so I am going to order up a 1350 conversion joint which is a 1.18 diameter. If it is too big, I'll just go ahead and get another 1330 and stick it in.
