Moser 9" additive change
Old Aug 10, 2008 | 11:53 PM
Pharm0r's Avatar
Default Moser 9" additive change
I searched a little bit, and came up with alot of nothing.
Anyone know were i could find a good write up of how to change the gear/limited slip oil in a moser 9"?
Thank you much
Old Aug 11, 2008 | 04:19 AM
EPP's Avatar
EPP
The Truetrac does not need posi additive, just 80/90 weight gear lube. Bob
Old Aug 11, 2008 | 09:43 AM
Pharm0r's Avatar
hwo do i change such lube?
Old Aug 11, 2008 | 10:30 AM
Black8Banger's Avatar
does yours have a drain plug and a fill plug?
if so its pretty self explanatory.
Old Aug 11, 2008 | 11:38 AM
Pharm0r's Avatar
not that i know of, ive looked....it looks pretty much like i have to unbolt the damn thing...
Old Aug 11, 2008 | 11:49 AM
ShevrolayZ28's Avatar
Or you could use a pump to suck the fluid out the fill hole.
Another option would be to install a drain plug. I drilled a hole and tapped it to pipe thread, but if you do it with everything still in the car, you might leave some metal shavings inside.
Old Aug 11, 2008 | 01:32 PM
yea if it just has a fill hole then you either have to suck the fluid out or take out the center section.
Old Aug 11, 2008 | 01:33 PM
Jawsgear's Avatar
You can pump it out, Ideally it is best to pull the 3rd member if you do not have a drain plug though.
Jeff
