Help Me Choose a Ratio
Engine Wise Im Running:
2000 LS1
224/224 112
QTP Stage II Heads
Full Bolt Ons
Tranny is
T56
Rear Ford 9"
3.45 Now, Cruises 1500 at 60mph with 275/40/17s. The car feels quick but a rear change would make it a whole lot better im sure.
As for the track I have a different set of wheels I will run
Draglites with 27*11.5*15 for rears.
All the time at the track it will either be 26 or 27 inch slick.
I'm planning a 4.10 ratio and was looking for some insight from you guys. At 60 with the cam its alittle surgy now.
With your mods and on that tire, would you cross the line in the quarter mile still in 4th gear? I've been debating on going to 4.1x's with my 9" rear swap, however I don't want to have to shift into 5th near the end (which may or may not be an issue).
I went with 3.70s and love them. 6th gear is more usable than my stock 3.42 and I'm not stroking gears as often as the 4.10 guys....
There was a NOTICEABLE gain in acceleration going from a 3.42 to a 3.70...
My philosophy is, build enough motor and you don't need a real tall gear...
I did with mine but off the rev limiter just past the markers (12 bolt Moser). I recently installed a FAB9" with 3.89's so I'm not sure what to expect running the MT ET Street Radials.
