The FAMOUS driving VIBRATIONS !!!!!!!!!!!!
Old Sep 1, 2008 | 07:18 PM
tylergarceau's Avatar
Default The FAMOUS driving VIBRATIONS !!!!!!!!!!!!
Ive seen all the posts on the driving vibrations, turning the drive shaft 180degrees, checking the u joints, changing the pinion angle. I guess what i want to know since i cant seem to get rid of it!? is it BAD to continue driving with ? i mean 70-100 it just vibrates and its like what the hell. ? do i have to find a way to fix this to be safe at the track and or street.
Old Sep 1, 2008 | 08:03 PM
EPP's Avatar
EPP
Yes you do, something is wrong there. Bob
Old Sep 1, 2008 | 09:11 PM
SLP Firehawk's Avatar
did u check out ur tires?? they could have flat spots or bad cords in them
Old Sep 7, 2008 | 11:24 PM
JASON 77's Avatar
have the same issue i have been trackin for 2 months now. ever since i put my 9 inch in from EPP. might try the longer driveshaft next.
Old Sep 8, 2008 | 04:43 AM
EPP's Avatar
EPP
Thumbs up
I know of at least one customer who installed the one inch longer driveshaft and had his vibrations go away. It certainly isn't consistent that every car that goes with a nine inch and uses the stock driveshaft will end up with a vibration, but if you do have a vibration this could be the reason. Bob
Old Sep 9, 2008 | 06:32 AM
AFASTYZFR1's Avatar
order the PST shaft from EPP.....I know when I installed mine it seemed to be smoother
Old Sep 9, 2008 | 03:01 PM
JASON 77's Avatar
got a 1 inch longer drive shaft, the vibration is still there. any other thoughts? getting very frustrated here.
Old Sep 9, 2008 | 04:25 PM
Wesmanw02's Avatar
Check all your wheels/tires and make sure they are balanced. Bring them to any tire place, they can check and balance them for probably $5 a piece.
Check your rear wheel bearings. If they have play in them (wheel moves up and down in axle shaft) you'll need to replace them with new ones.
Check your pinion bearings as well. If there is play in the pinion shaft, you'll need new pinion bearings.
Old Sep 10, 2008 | 08:57 AM
chieftransam's Avatar
I've got a similar vibration and after getting a longer driveshaft it still vibrates. Although now that I think about it mine only vibrates badly when the car is coasting (50mph+) or decelerating (50mph+). I have yet to figure out what it is! Any ideas?
Old Sep 10, 2008 | 12:26 PM
AChotrod's Avatar
Did you have your DS rebalanced? I had the same prob with my stock 2.5 steel shaft switched to a 3 inc aluminum and its gone
Old Sep 10, 2008 | 02:10 PM
You know I'm not exactly sure about that. I know that I have a 3.5" steel driveshaft, but I haven't noticed any weights on it. I'll have to check that out asap.
Old Sep 11, 2008 | 01:19 PM
382ssz28's Avatar
Look at the yoke on the diff real close. Measure the thickness where each joint goes and measure to see if each side is EXACTLY the same distance frome center. I had installed new yokes on 2 different diffs in different years, 1 12 bolt and 1 Dana 60, and the yokes were the culprit. The 12 bolt yoke was off to one side .064". We tried everything. I was getting frustrated as my customer wanted his car. By chance I noticed the tips or ears where the joint was to be centered were not the same thickness. We measured and found the yoke defective, put a new one on and it worked. The Dana, 6 years later, was similar. The holes for the straps were off to one side just a little. Being new parts you'd think to look somewhere else. But it was overlooked for something more suspisious, like broken mounts, driveshaft/balance, pinion angle, etc... Hope this helps.
Old Sep 11, 2008 | 07:58 PM
bad6as's Avatar
i had a bad vibe too at speed. it was my d/s, the front has that rubber ring as a dampner, it was bad
