3.42 swap from 2.73's now hitting rev limiter??
Old 10-09-2008, 09:24 PM
mikenews's Avatar
Default 3.42 swap from 2.73's now hitting rev limiter??
I put a complete rear out of an M6. Gears are 3.42 obviously. Car runs great, but it seems to be hitting the rev limiter. I used my handheld divinnci tuner and just corrected for the gears. Speedo is correct. I left the rest of the tuning at stock. I'm not spinning and it seems to bounce off the rev limiter at 6K. Doesn't matter it I nail it from 50 to 90 it will act up. And I know I'm not spinning at 70mph...lol. And yes that stupid ASR is off. Any ideas???
Old 10-12-2008, 09:37 AM
mikenews's Avatar
problem solved...installed tuning program from handheld..raised shift points, now all good!!!
Old 10-16-2008, 06:19 PM
99_ls1_z28's Avatar
Have you been to the track and ran with the new gears? I have a friend that wants to do that, but undecided between 3.42's or 3.73's. It's cheaper to just buy a whole rearend than installing 3.73's though. He also has 2.73's.
Old 10-16-2008, 08:23 PM
mikenews's Avatar
No I haven't run at the track yet hopefully soon. But I am very very happy with the way she moves out now. This is a daily driver for me so I think the 3.73's would be too much gear for me. You can definitely tell she got gears. 110% satisfied with the swap! Best mod yet 4 me.
Old 10-17-2008, 03:14 AM
IvanGTStang's Avatar
what cars got the 2.73 and what years got 3.23 auto
Old 10-17-2008, 04:48 PM
Internet Mechanic
BlackScreaminMachine's Avatar
Yea I was about to say, the shift points are going to be all goofy now. lol.
Old 10-17-2008, 05:08 PM
mikenews's Avatar
yes...because it revs real quick now.........have to tune it with handheld
Old 10-17-2008, 05:14 PM
yeller_xtc's Avatar
what did you change your shift points to?...i'm fixing to do the same swap.
Old 10-19-2008, 11:14 AM
mikenews's Avatar
I am currently running the #1 program on my handheld (Vinci / crane power max) which is stock cam, with minor bolts. I changed the axel ratio to 3.42. It shifts at 6200 rather then with 2.73's it shifted at 5900.
Old 10-19-2008, 11:54 AM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
Copied from a sticky
98 Auburn, 99-02 Torsen
M6 GU6 3.42 Standard
A4 GU2 2.73 Standard
A4 GU5 3.23 Optional (standard gear set with an SS/WS6/Firehawk)
A4 G92 3.15 (Vette optional)
28 Spline Axle 10 bolt rear end
