Clutch recommendations for SS
Tonight at the track my clutch slipped really bad & then either the clutch came apart, or the output shaft on my SS is broken. Either way I need a new clutch. I have a dealer hook up & can probably get it warrantied. Between myself & my wife we probably have around 200 passes on the car in just over 9k miles. Horsepower was anywhere from stock, to around 410 rwhp & now it's about 470 rwhp. Also sometimes it's been sprayed to about 650 rwhp & running in the 10's. When the drive train went it dead hooked on the 20's, no telling what it would have shorted if it wouldn't have broken on the launch.
Video of it idling if in case people don't believe my HP numbers. That is through exhaust, not through a cutout, I am going to go with dual cutouts & a more quiet muffler setup. I already have the cutout.
http://www.youtube.com/watch?v=ZEetM7I-vv8
I may be in luck, GM has issued a TSB on the output shafts breaking on early build cars which mine is. Also read something about GM warranting their clutches for 12k miles due to Master Cylinder sticking problems. I'm having both. I also may have an in with a GM dealer that will turn a blind eye to my mods. ![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
I'll know more tomorrow.
I've looked at a few dual setup's today, leaning towards one of them.
Just want to do it once, or rebuildable like most dual's are, car is not close to being maxed out & once I get there, it would be nice just to build a motor & boost it big, get the clutch done now & get it right. it's already almost all the rear suspension you can get for it. Will just need motor & turbo kit + a few supporting mods to get an easy 1krwhp.
