Gen 5 Camaro Drivetrain Tech Clutch, torque converter, rear end, axles
HPS 2010 Camaro TH400 Conversion
Old 10-24-2011 | 12:03 PM
chris@hps's Avatar
Default HPS 2010 Camaro TH400 Conversion
HPS is doing a TH400 Conversion on one of our customers 2010 Camaro.
He recently purchased our Stage 5 Package from us producing 615rwhp and 601rwtq @ 10 psi with the 6 speed. Now he has decided he wants to race a little more often at the track.
Conversion consist of:
PTC TH400 with Tbrake
PTC FI Converter
PTC Flexplate
HPS Custom Transmssion Cross Member
HPS Custom One Piece Driveshaft
A Video of the dyno pull
http://youtu.be/G-CmfivhOx0
Old 10-27-2011 | 01:29 PM
chris@hps's Avatar
The TH400 is installed and best part of all, we were able to use the stock transmission X-member..
Chris
Old 11-12-2011 | 06:44 PM
avalanchett's Avatar
how much for this option?
Old 11-14-2011 | 10:30 AM
chris@hps's Avatar
I sent you a PM.
Chris
Old 11-14-2011 | 02:38 PM
navyblueSS's Avatar
Nice!
Old 11-14-2011 | 04:06 PM
chris@hps's Avatar
Also need to mention that at this past weekends race at Darlington for the IRS race, first pass off the trailer we ran a 10.97 and then the best pass of the day was a 10.87. Not bad for a Maggie on 10psi and a 6rib setup and Drag radials.
Chris
Old 11-21-2011 | 09:16 AM
edmanet's Avatar
Chris
Was his camaro a M6 or a A6 ?? This was tried on a G8 but the car
wouldn't start w/o the A6 tcm plugged in, even though it wasn't
needed anymore.
Old 11-21-2011 | 10:26 AM
chris@hps's Avatar
needed anymore.
This car was previously a M6.
Chris
Old 11-22-2011 | 10:52 AM
BlueThunder2's Avatar
Very nice Chris!
Old 12-03-2011 | 01:40 PM
chris@hps's Avatar
The TH400 Conversion has been completed for appx. a month now. The first time out to the track with the new setup on drag radials we ended up breaking the sprag in the transmission. However with only 2 gears we managed to run a best of 10.89@ 130mph. We also added added a 75 shot of NOS and when leaving off the the line with the spray it would just smoke the tires. Same thing when we leave off the 2 step as well. Customer is getting a suspension upgrade as well as a few other goodies. Here is a pic of the interior where the shifter fits in the stock location.
Chris
Quick Reply: HPS 2010 Camaro TH400 Conversion
