Gen 5 Camaro Drivetrain Tech Clutch, torque converter, rear end, axles
Monster upgraded slave cylinders @ SDPC
Old 06-02-2015, 10:48 AM
LS1TECH & Trucks Sponsor
Scoggin Dickey's Avatar
Default Monster upgraded slave cylinders @ SDPC
Preinstalled on the slave by SDPC when you buy a slave and the bearing support!
One of the best upgrades we've seen for the GM hydraulics in late model GM application is the Monster throwout bearing support. Eliminate a huge point of failure in your GM hydraulics with this upgrade, and you don't even have to install it yourself. If you buy a new GM slave from us and the Monster support at the same time, we will install the bearing support before shipping.
Couple this with any clutch of your choice, and you really can enjoy one stop shopping right here at SDPC. Just give us a call with your application and we will price the slave cylinder for your application. We do not get beat on price on genuine GM parts! The Monster support is $79.99 and we won't charge you for swapping it onto the slave before shipping it out.
Stock.
Tools Required.
Pull off the throwout bearing.
Gently pry off the retainer ring.
Remove it and sit it aside.
Monster's new billet support!
Replace the stock plastic support with the new Monster support.
Place the retainer back into place.
Tap it down to securely hold the slave together.
Put the T/O bearing back in place and it's ready for installation in the car.
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Old 06-03-2015, 09:51 AM
SNLPerformance's Avatar
Thanks Scoggin Dickey!!!
Old 06-03-2015, 11:49 AM
LFSADRG's Avatar
I assume this is for the Gen5's but any chance it will work with the Fbody/GTO slaves?
Old 06-05-2015, 07:47 AM
The GTO and Fbody slaves are put togther differently with different parts, this is not applicable to them, no sir.
__________________
Old 06-22-2015, 11:25 AM
To the top!
__________________
Old 06-22-2015, 11:42 AM
leftcoast32's Avatar
Can you check the part number for the 2015 Z28 and see if it is the same part number and price for the upgraded slave? Thanks!
Joe
Old 06-22-2015, 05:54 PM
The Z28 uses a different slave than the SS. It's abotu $20 less than an SS slave
__________________
Old 06-22-2015, 05:56 PM
NOTAV6's Avatar
I lost the plastic bearing support on my own 2010 Camaro SS and made sure to get the Monster support when we put a new slave in a month ago, so that it would not happen again, especially since I was about to take the car on the long haul for Power Tour. Great upgrade to the factory slave and improves the reliability greatly.
Old 06-22-2015, 06:39 PM
Can it still use the Monster Upgrade?
Old 06-22-2015, 06:47 PM
LS1TECH & TRUCKS Sponsor
Sales@SDPC's Avatar
Yes you can use the Monster bearing support in a 2015 Z28.
__________________
Travis@SDPC
(800) 456-0211 Ext. 383 SDPC Instagram
Old 06-23-2015, 10:52 AM
Thanks! I will give you a call next week to get it coming this way.
Old 07-30-2015, 08:09 AM
To the top!
__________________
Old 05-25-2016, 01:20 PM
Sales@SDPC's Avatar
Any of you guys doing a clutch change give us a shout to get a Monster Bearing support upgrade so you wont have to chance getting into it again when it eats the stock plastic piece.
__________________
Travis@SDPC
Old 07-08-2016, 09:36 AM
Bump!
__________________
Old 11-11-2016, 08:08 AM
To the top!
__________________
Quick Reply: Monster upgraded slave cylinders @ SDPC
