Suggestions for Gen5 Camaro
I just installed my roto-fab intake and jannetty tune to compliment my LT's and no cats. I don't care what anyone says this car is now stupid fast compared to stock and whats funny is I got 12.70's out of it stock. I have yet to install the air scoop and washer bottle relocation kit.
Come on spring!
Come on spring!
I was running the car in the 13 teens at 110 on the first 2 outings at 300 and 600 miles but could not get the hang of the launch. I let the rears down to 26 and fronts up to 42 but didn't help. I watched a few vid's and did research and most good drivers were holding RPMs up and slipping the clutch out. My last outing at 900 miles I held the rpm at 3200 and rode it out, I left the tires at stock pressure. went 13.00@110.8 then 1286@111.3 and then the 12.75. I think with more practice I could have maybe seen a 12.5 but that was it for the stock combo.
These cars rock when driven correctly.
#34
wow glenster thats great times, i knew these cars were capable of running 12s, i cant wait to get my 12, should be here in a month
very nice times, 430 to the wheels is insane!!
#35
ARH and KooK's are your two top brands now for HP. If you want a Stainless header that you will never have a problem with exhaust leaks I would go with the XS Power Header, its made from 321 stainless and is more suited for higher temperatures than the 304 stainless the other companies use.
#37
#38
Dynos can vary greatly though...if you get a heartbreaker you may only barely surpass 400 with bolt ons (I have seen that happen as well)
But for the most part like I said...with the right bolt ons and a good tune 430-440 has been done many times.
The difference after headers and a tune was incredible...it felt like I added a cam lol. The cars have a lot of torque management when stock as well. Have your tuner get rid of it completely (most will for the most part without asking)
#39
I can't stress the change after tune and intake, its hard to believe. I do know my 2000 Z28 ran 12.3's before the tune and 11.7 afterwards. Dyno went from 360 to 415 so tuning is a must when the package is finished.
#40
Most bolt on m6 cars can hit the 430 mark if you run an under drive crank pulley and have a good tuner. The average ls3 bolt on car without a pulley is usually around 415-420rwhp.
