SS Heritage Emblems
Here is a DIY on how to change the grille.
http://camaro5.com/forums/showthread.php?t=64375
For the rear, I have a 2010 that has the holes in the trunk. If it didn't have the holes, I'd take the SS off both front and rear. I can't remember if there are a couple of small nuts you have to take off from inside the trunk to get the bowtie off. Once it is off though, Just use 3M tape made for emblems. Get the same SS you use on the front. You will need to bend it (the middle) to get it to contour to the body line that runs down the middle. For the front, You will need a little bracket to hold it on the grille.
