Speed Inc. 2010 is in for the TVS2300
#46
track results
so... bad day to go to the track and try and get a feel for the new setup. The ride was over 2 hrs in traffic and then over 1 hr in tech. We gave the car about a 15 minute cool down and went for it.
car just turned 1000 miles on the trip up to the track
1/2 tank of 93 BP
race weight..I would say 4K
tires were M&H 345/35/18 : http://www.mandhtires.com/store.php?...on=show_detail
2 runs is what I got...Jim got one off and Dan had a clutch pedal on the floor issue.
#1 tried a 3800ish launch with a smooth, but quick clutch release which resulted in a little spin and hop which I quickly pedaled through. I power shifted at approx 6500 ( stock tach ), but it did not seem to like the power shift at times...slight hesitation since I think the flare would hit the limiter. I tried to run out 3rd gear, but just short of the stripe the car nosed over from the limiter.
2.1 60ft
91 1/8
12.38
119.5
#2 was about 1 hr after the above mentioned clutch pedal stuck on the floor for Dan I decided to try it again. The hood stayed shut for the time it was sitting and the clutch still had a horrible smell. I worked the car through staging for about an hr and then finally got the second run. I came out at approx 3200 ( worried about clutch ) with a quick, but smooth clutch release again and had just a touch of spin/hop and stayed in it. The run felt good here...did not power shift 1-2 and shifted about 6200 on all gears + pulled 4th this time.
1.84 60ft
93 1/8
11.87
118.4
We really feel a gear or shorter tire would really help the car work well both on the front and back of the track
so we are very happy with the car considering lack of time last night to get a feel for the car. We will get back out and work the ET some very soon.
1/2 tank of 93 BP
2.1 60ft
91 1/8
12.38
119.5
1.84 60ft
93 1/8
11.87
118.4
#56
Oh thank god!....I was definetly the black T/A that u freight trained on the highway on the way home from GLD last night!....car looked great and too everyone wondering I can vouch first hand the car moves as Larry pulled my cam only T/A and friends srt4 extremely easy! Glad to know this was the supercharged one you guys were working on, was affraid it was stock!
#57
I kinda figured you both thought it was your typical crawling new SS since it sounds stock.
see you around
#59
Sunday results
Sunday results
I got the 60ft figured out pretty well at least for yesterday.
4100ish rpm with a smooth quick release
1.71
1.72
We got another new best ET with the car as well.
11.80@117
The above run was after about a 1/2 hr cool down after a 1+ hr. drive.
race weight 4070 with a 1/4 tank of fuel
We need some weight reduction and more power a.s.a.p
1.71
1.72
11.80@117
