Eforce + cam + boltons...what pump?
what fuel pump are you guys going with?
I have a guy bringing in a 10' that currently has full exhaust, but wants a eforce(he bought it already) and bought a cam too. I know the stock pump is screaming at a touch over 500hp N/A, so i'm sure this car will need a pump with boost.
i've messed with a couple big n/a hp 10s, 520-600 WHP and they needed pumps. What are yall running for boosted cars? twin in tanks?
got the car put together, dissapointing numbers though.
I cant tell if maybe the belt is slipping, clutch is slipping (its stock) or what
tune up is good and its on 18-20 degrees with no knock retard, feels strong on the street driving it.
but 470hp/560 ftlbs just seems like a weird combo, not to mention the car made 417 w/ bolt ons. seems to me like that power number is what itd make cam only, tq is decent but idk. maybe its dumping boost or something, I need to put a gauge on it and see whats its even making on the pulley that comes in the kit.
cam is a 225/230 .618/.612 114
Look at the IAT rise... that blower will want a lot of timing; barely lower than stock. Towards the end of the pull as the IATs rise, the timing falls off. A small timing loss makes a big HP loss on a PD blower. Look at what your timing is doing in the last log you took up top.
she was at 19.5 from about 5000 to redline.
didn't seem to want any more than 19.5 or 20 degrees before hitting KR, I can hear it ping with any more than that. I'm sorta stumped, but I guess it is what it is. Sounds clean and pulls great, it could always be the dyno or clutch acting up.
I found out this was the 6lb pulley for sure also.
At face value, it would seem like you should be able to run more than that... I had a 2010 with a 10:1 427 and spinning a mag2300 to make 15psi on that big engine and I was running 19-19.5 on it up top to finally make the number. It was still making sizeable gains with each degree of timing up until about that point. What kind of IAT rise does the blower have through one pull?
Edelbrock said to put at least 24 degrees in it, but it just dont want it!
what kind of air fuel have you seen on a blown ls3 do the best? I've got it at mid 11s across the board. maybe i'm just completely wrong
LS1Tech Sponsor
They like timing due to the efficiency but I've seen the same problems your having. On a non-load dynojet I could run 20 degree's of timing.On my loaded mustang it wouldn't take over 15 degree's without pinging.
You really need to log boost and the dyno can show belt slip if you look at MPH. The Cam could be bleeding off or floating valves.
The blower dictates the power more than the Cam will.
Thanks for all the input guys. When he gets the pulley in i'll throw it back on the dyno and log for boost and see whats going on. If the cam is dumping boost, it shouldn't be as bad on the 2.75 pulley as it is now, if its doing that at all.
LS1TECH Sponsor
very true i have trouble getting more then 16 degree in these things with Maggies at 8psi.... i to have a load dyno (dyno dynamics) on the street you may not see knock retard in the low gears, but what about in 4th,5th gear ?that is when there is alot of load on those puppies and thats when knock happens.... the car has to be tuned for all environments, not just a inertia dyno and low first few gears.... 20 degrees is alot of timing in my opinion
Well I figured out belt slip was horrible, its got a shorter belt now.
ONLY change was shorter belt. it made 640HP and 590 Tq. Still on 6lb pulley.
He still hasn't got a boost a pump for it, so this is on injectors and stock pump. I told him not to run it hard until he gets the BAP. It goes leanER at about 5600 and up.
needless to say he's happy now with it.
