SS with upgrades or 1LE package??
Old 01-09-2013 | 05:31 PM
DJBlackSuperman's Avatar
Default SS with upgrades or 1LE package??
Been looking more into the NBS camaros, Im torn between buying a used one for around 25K or biting the bullet and buying a new 1LE... It will mainly be a street car but i have looked into doing track days and there's a few tracks that are close. Im not interested in beating any other cars on the road or parking lot pimping... I like to drive FM roads and have a good time. Ive got my cbr 1000rr for going "fast" so the camaro will be my "family fun/ travel" car. As far as mods Id leave the 1LE mostly stock but the SS would get some carbon fiber parts hood/ truck/etc and suspension upgrades Lowering springs/ frame connectors etc... Im just curious to see which way might be the best way to go... Feel free to input!!! Thanks
Old 01-09-2013 | 06:21 PM
DietCoke's Avatar
Used SS and some 1LE suspension bits is certainly the best bang for the buck
Old 01-09-2013 | 10:38 PM
whatd you do to cut 400 lbs off the car?
Old 01-10-2013 | 12:15 PM
Gunslinger09's Avatar
I would do the used SS too. In fact I did. Get aftermarket parts with Polly bushings and replace the other bushings with poly units and call it a day. The only advantage the 1LE will have then is the 3:90 geared rearend. I have seen the GM ring and pinion sets selling for $250 or you could go after market 4:11s if you have the coin.
Old 01-10-2013 | 01:12 PM
the 1le sway bars are smaller than ones available from aftermarket tho... im curious to know which ones are better... aftermarket companies should do more test videos... ive seen a few out there but there arent that many... id guess they have too many vehicles to test...
Old 01-11-2013 | 02:17 AM
I would go with the aftermarket pieces. Just by virtue of being lower volume of production the quality is generally better.
Old 01-11-2013 | 10:25 AM
i like the look of the granatelli 1G bracing bolt on kits. i think that would be a given on the 1le or a SS.
Quick Reply: SS with upgrades or 1LE package??
