to all of you doubters on weight!!!!!!!
According to gm the new camaro ss lapped the ring 2 seconds faster than the new turbo cobalt ss. Check out car and driver's lightning 2008 lap to see how well the cobalt did. Theoretically, the camaro ss should be as fast or faster than the cobalt which would put it in some pretty insane company for a ~$30K car in a test that measures handling, braking and acceleration. As for the gas mileage, it is suppose to be slightly better than the fourth gens. New cars weigh more, especially ones that have to remain affordable to the average buyer. I read the complaints and think they are unwarranted. The new ss will out perform the fourth gens in every way yet people are complaining because they don't like the look of its weight written on paper.
to OP.... when you sober up do some more calculating because 7.30's are not even close!
hahaha, that must have been one hell of a Factory Freak then.
Your friend either had more mods than he told you or hes lieing. There is no way in hell a 300whp car would run low 7s in the 1/8th probably low 11s in the 1/4. The only car I see that could have a chance doing that would be a Dragster. The racing calculators(which are dead on with what I have ran in my car) say 3600lbs with 350hp(flywheel) say your buddies car should run 12.60s.
Your leaving something out.
My car is defiantly not stock and the calculators are dead on for me. For my MPH anyway for the ET its getting closer. Thats why I was useing the calculators and trusting them, because I have proved them right.
My car has a **** load of stuff done to it and I can only manage a 7.9 and I have 4.10 gears and a manual. I launch at 5000rpms. So tell me how your buddies car with 300hp and just a stall and same gears as me can run 8 tenths faster than me with 360whp?
This is why your logic is flawed because you are not taking into account all the variables. Do not ever compare a manual car with a stalled car at the drag strip. It does not matter that you launch at 5000rpms, you are not getting torque multiplication like an auto, further as you are shifting gears your RPM is dropping out of the powerband, a stalled car runs at peak power all the way down the strip, my RPM never dipped below 5000rpm down the track. You are comparing two numbers that are obtained in two completely different ways.
I doubt the new Camaro will obtain 7.30’s with a stall and gears, but that remains to be seen, realisticlly 7.70's-7.80's. No one knows the actual weights on these cars or the variances that customers will observe, add in to the mix IRS and those 60fts are not as stellar as a solid rear axle car. But I can say this, there is going to be variances in weight. The 4th gens proved that with 400lb variances.
Well your car is a pig then, not all 4th gen weighed the same from the factory. My 2001 Camaro SS is a stripper with me in the car it weighed 3480 (3290 without me) on the scales. All I had was a Yank ST3500 stall converter, a set of FLP headers, lid, and a set of BFG 275/40/17 drag radials on stock wheels all the way around. Just the spare tire, rear seats, and jack removed. At MIR I was cutting 1.59 60fts, crossing the 1/8th at 7.538, and finishing the ¼ at 11.87@113mph with a car that was on the dyno at 326rwhp and 342rwtq. There were cars similar to mine that were 3 to 4 tenths quicker because they were using 4000 to 4600 rpm stalls, gearing, and taking advantage of location and good weather.
I doubt 100hp difference, the 01-02 LS1 cars were severally underrated at 315hp and were much closer to 360-380hp cars. The new L99 is rated at 400hp and you will not see numbers in the Camaro going over 430hp, the Vette which has a better tune on a LS3 is just barely seeing 450hp stock. The biggest difference will not be the peak power of 70 or so hp, but the broader power curve of the larger displacement engine.
Gearing is not feasible on such a car, even on the 4th gens running a gear did not result in net gains in the ¼ or in the 1/8th for that matter. The steep 3.06 first gear in the 4L60E was perfect for the standard 3.27 rear gear. You may have gotten away with a 3.73 gear and gotten off the line if you had a good track and great tires, but 4.10’s were nothing but spin city. The new 6L80E has a first gear of 4.02, you are not going to be running gears on this car.
No one ran 4.10's on an automatic car and kept them, they did not result in gains and even by chance if you did hook, they typically broke.
#32
1.59 sixty foot, 7.51 in the 1/8th and an 11.86@113.62 in good air at Atco.
Dyno'd roughly 335rwhp/336rwtq.
#33
The new car will have 3.27s of course.
#35
The problem there will be the TC and ABS.
#36
The LS1 FBodies were actually around a median of 350 HP at the flywheel (when looking at what ppl dynoed. There are some freaks out there. But working with roughly 15% drivetrain loss they come to 350 HP at the flywheels regularly. 360-380 HP is overstating the case by quite a bit and only rests on the evidence of some factory freaks. Likewise the LS3 will probably be around 450 HP realistically.
W
W
#37
W
W
#38
i bet you BLK85 is with all these nearly stock auto guys getting 7.50 in the 1/8
he's probably saying and i quote i have a ton of **** done to my 6 speed and
#39
#40
No use arguing with people that are completely wrong. I doubt the guy you quoted runs 113mph with 335whp. I run 112 all the time with 360whp. The 1/4 time of 11.8 I could believe, but mph is determined by power. So this guy has less power than me but ran 1mph faster. Theres something more to this story. Just because you run a quick time once, that doesnt mean crap to me.
