Texas Speed Prototype 2010 Camaro SS Induction
We recently finished testing 5 different versions of the TSP 2010 Camaro SS air intake kit. We've finally decided on a version that worked the best overall on the several cars we've tested it on. This kit will feature everything you need to do a complete install on your SS in your driveway. The combo has been dyno tested with several different modification combos.
Here's a copy of a couple of the dyno sheets & a image of the prototype. Keep in mind it will have some changes & look a lot nicer when it's a final version, this is just a basic proof-of-concept prototype. The final version will include several changes such as trim for the heat deflector, full ceramic coating, just to name a few...
Pricing is available on our website & the first run of intakes will be ready in less than 2 weeks!!
![](http://www.precisionracecomponents.com/2010intake.jpg)
![](http://www.precisionracecomponents.com/pulleyintake.jpg)
![](http://www.precisionracecomponents.com/headerintake.jpg)
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic110569_2.gif)
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
We haven't posted results of the headers results by themselves....but they did make more than 10rwhp. The difference in the two graphs above, is that the top one doesn't have headers but does have the pulley kit. The second one had headers, but no pulley. Also, it should have been labeled as no tune on the 2nd graph as well.
Make more sense?
Make more sense?
__________________
15hp just from the induction?! that's pretty good. I like the way the headers sound with that exhaust as well.... is it real loud in person or just loud enough?
thanks for getting the mods out quick because some of us don't really care about factory warranty.
I think it's just right! I really do like the tone and volume of the headers and Rumbler 5 catback alot better than I like comparable combos on the 4th gens. It's a much cleaner quality sound (likely due to the 4 muffler combo)!
__________________
