L99 to Ls3 Swap HELP!
On the timing chain cover, the l99 has a 4 prong plug and the new ls3 timing chain cover has a smaller plug. What goes there?
http://www.youtube.com/watch?v=1-IDQPEK9ag
ill post pictures and details if anyone wants.
You will need THESE PARTS for DOD delete only.
Head gaskets
Head bolts
GM Valley cover(nonDOD)
Lifter trays (LS2)
Lifters
Someone to turn it off in the tune.
Depending on the valley cover you use, you may need the tube that runs from the valley cover to the intake. Or make provisions for blocking it off or routing it to the normal PCV system.
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
#1 What crankshaft pulley did you purchase? PN?
#2 What exactly are you asking about the rest?
#3 If the crank pulley did not fit in the first place due to the timing cover, then it is the wrong pulley. You are working backwards. You need the parts to fit the engine, not the engine to fit the parts.
