Gen 5 Racing Tech Heads, cam, valvetrain, short block discussion
LS3 Conversion, Cam Heads+Misc
Old Apr 8, 2013 | 06:23 PM
  #61
Hart_Rod's Avatar
Just a few threads i found:
https://ls1tech.com/forums/generatio...re-relief.html
https://ls1tech.com/forums/ls4-perfo...step-here.html
https://ls1tech.com/forums/conversio...inate-dod.html
Old Apr 18, 2013 | 09:33 PM
  #62
Gunslinger09's Avatar
MGW3,
Any updates? I really want to see it back together and I'm curious for dyno numbers and track times.
Old Apr 28, 2013 | 06:26 PM
  #63
Mrgoodwrench3's Avatar
Just received my heads back from WCCH. These things look amazing!
They are fitted with new stainless valves and BTR .660 springs. Richard at WCCH did an amazing job on these heads. I cannot wait to get this motor running. The cam is a custom spec from Pat G. More updates to follow.
Old May 18, 2013 | 09:12 AM
  #64
MGW3,
Any updates yet?
Old Jun 1, 2013 | 10:42 AM
  #65
Hart_Rod's Avatar
We need updates!
Old Jun 28, 2013 | 10:45 AM
  #66
Here is a little update on my project. Engine is together and back in. Now I am going to clean up the wiring to the injectors and coil packs.
Old Jul 2, 2013 | 12:19 AM
  #67
Very nice.
Old Jul 14, 2013 | 01:06 PM
  #68
LSXaddicted's Avatar
Where did you get the race baffles for oil pan and that radiator? I am building mine for track and Auto X but want to take every precaution as far as oil feed and cooling that I can.
Old Sep 24, 2013 | 09:11 PM
  #69
The oil pan baffle is from Improved Racing.
Old Oct 17, 2013 | 11:03 PM
  #70
Just added a custom automatic shifter.
Old Oct 30, 2013 | 10:34 PM
  #71
ScreaminRedZ's Avatar
registered user
Awesome job, the detail work you did on the engine came out amazing!
Any part numbers or further information on the upgraded transmission filter and transmission cooler? I need an upgraded cooler for my G8, and this is the first I've heard of the filter upgrade.
Old Dec 7, 2013 | 01:57 PM
  #72
Car is looking and running amazing! Big thanks to the Pat G. tune. Next I am working on some Body, Tire and Wheel mods. Stay Tuned.
Old Jan 1, 2014 | 06:37 PM
  #73
Camaro idle video.
Old Jan 1, 2014 | 07:25 PM
  #74
Hart_Rod's Avatar
Sounds great! How much did it dyno?
Old Feb 18, 2014 | 12:23 PM
  #75
scottywheels's Avatar
Originally Posted by Gunslinger09
Have you upgraded your trans? I have heard the A6 has some durability issues and that's why Chevy went with a lower power L99 rather than the Ls3 in the auto.
I MADE 719 rear wheel hp and my trans was fine as long as you get it tuned
Old Feb 18, 2014 | 12:27 PM
  #76
[QUOTE=Mrgoodwrench3;17355845]Just received my heads back from WCCH. These things look amazing!
The heads are not a good bang for the buck... kind of a waste of money... With forced induction guys making 750 rwhp with stock heads just upgraded parts and no porting
Old Feb 19, 2014 | 10:08 AM
  #77
For transmission upgrades I changed to a high flowing filter. The inlet port is 3 times larger than sock. Also changed over to the B&M trans pan. It hold an additional 1.7 quarts of ATF. I have the Flex-a-lite trans cooler up front. It does not run through the radiator.
In my opinion one of the biggest factors in keeping the 6L80 alive is a proper tune. Mine was done by Pat G. and it performs flawlessly.
Old Feb 19, 2014 | 10:09 AM
  #78
[QUOTE=scottywheels;18029066]
Getting to 500RWHP N/A with stock heads through an automatic is not easy. Not a waste of money at all in my opinion.
Old Feb 19, 2014 | 01:56 PM
  #79
grocerygetter's Avatar
[QUOTE=Mrgoodwrench3;18031254]
it's been done a few times over for sure though.
Old Mar 3, 2014 | 11:08 PM
  #80
registered user
Thanks for the info! What brand is the transmission filter?
