Gen 5 Racing Tech Heads, cam, valvetrain, short block discussion
camaro with 5.3 what the *&^%$
Old Jun 8, 2006 | 10:52 AM
hydrotroop's Avatar
Default camaro with 5.3 what the *&^%$
From what I heard is that the camaro in 2008 will be coming with a 5.3 v-8 with 300 hp. Now this just may be rumors which I am hoping but a camaro with 5 hp less then it was ten years ago is simply retarded . I pray gm atleast comes out with a 350 hp machine in a stock z-28 in 2008 because a 300 hp camaro is gonna be weak for the time and hell ten year old ls1's are gonna walk it probally.
Old Jun 8, 2006 | 11:25 AM
TransAm52804's Avatar
Seeing as how the 4th Gens are most likely to weigh hundreds of pounds lighter than the new 5th Gen, they better be making some damn good power to make up for it.
Old Jun 8, 2006 | 11:51 AM
JAvenger007's Avatar
not sure where thats from but sounds pretty final that its gonna have either 400hp ls2 or 405 hp 6.2 and an optional ls7 in a year or so to combat new gt500. its also target weight is 3600 lbs with the ls7 likely weighing 3500 and costing around 45K.
Old Jun 8, 2006 | 01:08 PM
98redM6's Avatar
The 5.3 would just be an optional engine. It is rumored to have a high output V6 240-260 hp, standard V8 (like a 5.3) 300-320 hp, and an optional V8 350-400 hp. I expect there to be a release of a LS7 or the like a couple of years after the first are released.
Old Jun 8, 2006 | 01:18 PM
two step's Avatar
I think a 5.3 would make a great RS.
Old Jun 8, 2006 | 02:00 PM
ram09's Avatar
Well you could have the base V-6, RS 5.3 V-8 325hp, Z28 6.0 V-8 400hp suspension set up for cornering, SS 6.2 V-8 425hp suspension set up for drag racing, ZL1 7.0 LS7 V-8 505hp street king, set up for both cornering and straight line. Of course most of this wont happen, but its nice to dream.
Old Jun 9, 2006 | 10:19 AM
BAD2000TA's Avatar
I like your thinking. It truly is too bad that it won't come to fruition. But, hey, we can all dream.
Old Jun 9, 2006 | 11:34 AM
Turo's Avatar
With GM, nothing is final until it actually hits the dealerships (and I can test drive it ).
Old Jun 9, 2006 | 09:12 PM
JB_94_z's Avatar
5 different versions of 1 car?
base v6. mid level v8. big v8. and bigger v8, a v8 that isn't de-tuned..
the base v6 has been slightly rumored to be the 3.6 VVT engine in many cars right now.
Old Jun 10, 2006 | 12:30 AM
Josh2006's Avatar
well the camaro is supposed to save GM so it has to be versital not to mention its not too big of a deal there already making the engines so its not like there having to make 3 new engines for the car.
this is the basic layout of what i have read, i cant remember which mag but i think its MT, the only difference is your ZL-1 they have been calling the SS RS
Old Jun 10, 2006 | 12:33 AM
Josh2006's Avatar
V6 240-260 hp
that would be awsome this would be running with the mustang GTs
all i know is i want an SS 425hp hopefuly about 3500lb it will be running with the best of them. but we better hope that they make the base C6 alittle more powerful or we wont see a 425 hp option engine.
-Josh
Old Jun 10, 2006 | 09:50 AM
LTSpeed's Avatar
Originally Posted by TransAm52804
Seeing as how the 4th Gens are most likely to weigh hundreds of pounds lighter than the new 5th Gen...
What makes you say that? All the numbers I've seen show it around 3600lbs loaded. Are you referring to the fact that it's coming from Holden and the Aussie safety rules normally result in very heavy cars?
Old Jun 10, 2006 | 10:26 AM
Louie83's Avatar
I wouldn't be surprised if the 5.3 is the RS engine. They will most likely try to make it as fuel efficient as possible, but also have some ***** when you floor it.
Old Jun 10, 2006 | 11:58 AM
Basically I'm saying that seeing as how every new car coming out is far overweight, I wouldn't be surprised to see the 5th Gens be fatasses either. Granted, much of it is due to stricter safety regulations, but also because people are wanting all this electronic entertainment and luxury BS installed from the factory.
Christ, the new Cobras weigh over 4000 lbs, the GT's weigh 3600+ lbs, the GTO weighs 3800 lbs, and the upcoming Challenger is said to weigh over 4000 lbs. WTF is this crap. I remember when people used to bitch about 4th Gens being overweight... Hell they only weigh 3400-3500 lbs. Nowadays that'd be considered a lightweight.
It's sad honestly. Cars will be needing 400+ HP just to run the same times as the 350 HP LS1. An obvious example/s is the GTO (400 HP) and Charger SRT8 (425 HP): both those cars run high 12's/low 13's which is exactly what a stock, much-less-powerful LS1 runs. And on top of needing more power to run the same times, the bulky weight will be felt in the handling too. It sucks.
Old Jun 11, 2006 | 04:03 AM
JCurtin's Avatar
The More engine choices, the more sales. Options are always good. I sure as hell hope I can buy one and choose what I want. I mean if I want the big dog motor, dont make me buy heated leather, navigation and 20inch wheels. I want to put a check next to what i want!!
Old Jun 11, 2006 | 07:58 AM
Pipelayaz's Avatar
I agree...
Old Jun 11, 2006 | 08:07 AM
V8pwrdz28's Avatar
GM read this!
Old Jun 11, 2006 | 10:58 AM
jmurray87's Avatar
The engines that will be going in the camaro arent even in production yet. In 2009 whos gona want a LS2? LS3,LS8,LS9 are the 3 upcoming engines coming from GM a couple go to the camaro and one goes to the new super vette.
Old Jun 11, 2006 | 02:31 PM
Vendetta's Avatar
Better a 5.3L base motor than a V6 base motor like the Mustang has.
Old Jun 19, 2006 | 02:38 AM
Genesis_26317's Avatar
I betcha everyones REALLY going overboard on the new car expectations. I doubt they would make more than 3 different engines which is one more than most of the other cars they make. I mean come on this is the company that produces two different front wheel drive v8 engines.
Different engine set-ups are more likely. There isn't anything wrong with them putting out only 2 engines.
Base - v6 240 hp
RS - HO v6 260 hp
Z28 - V8 320 hp
SS - HO V8 350 hp
If its hp is 400 and weighs as much as the GTO its fuel economy is going to drop to 16-22. The competition is only 300 hp, 400 hp is a LOT more.
