Gen 5 Racing Tech Heads, cam, valvetrain, short block discussion
L99 and LS3
Old Jul 20, 2008 | 12:24 PM
HPT BANDIT's Avatar
Default L99 and LS3
I was reading this article and was wonder how much different is the L99 compared to the LS3. They said the automatic will make a few ponies less.
http://www.edmunds.com/insideline/do...topanel..1.*#7
I wonder how much different these 2 motors are. Is it just the DOD and the tune or is it cam and heads?
Old Jul 20, 2008 | 12:35 PM
383ss's Avatar
DOD requires a different cam. I would assume it is just the tune and cam that gives it 17hp less. heads, intake and the rest should be the same. it probably has a higher volume oil pump to provide the AFM function though.
Old Jul 20, 2008 | 12:40 PM
djsanchez2's Avatar
Should both be alum blocks right?
Old Jul 20, 2008 | 05:33 PM
Hans Grüber's Avatar
I am skeptical of this L99 engine.
I beleive that the mid-range engine will be a 360hp 6.0L L76 as found in the Pontiac G8.
I don't see the point of 2 V8's just over 20 hp apart.
I guess we'll find out if this is accurate on Monday.
Old Jul 20, 2008 | 06:16 PM
383ss's Avatar
yes, they will be aluminum
Old Jul 20, 2008 | 06:19 PM
TriShield's Avatar
It's not really two different V8s. The biggest difference is one has cylinder deactivation (lame) and the other does not. The L76 in the G8 is basically a variation of the LS2 just as the L99 in the Camaro is a variation of the LS3.
Cylinder deactivation does not work with manual tranmissions. It's the same reason the Challenger with an automatic has deactivation and the one with a manual does not.
Old Jul 20, 2008 | 07:27 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
DOD has no place in a V8 Camaro. This will take the 5th gen Camaro off my shopping list for good.
Guess I'm now looking for deals on A6 C6s.....
Old Jul 20, 2008 | 07:41 PM
djsanchez2's Avatar
Wow you are really butthurt about this DOD thing arent you? Can't it just be tuned out, if it's really that important to you?
HPT BANDIT's Avatar
Like everything else, someone will figure out a way to deactivate it. That shouldn't turn people off the car. I wonder how many people skip shift turned away?
Old Jul 20, 2008 | 07:47 PM
68Goatboy's Avatar
DOD has every place in the automatic V8 camaro, especially with the ever tightening emission and milage standards!
they'll get around the DOD for those looking to go fast int he automatics, but for the average driver its a brilliant addition.
and its not like the new DOD technology is the same as cadillacs old 4 - 6 - 8
Old Jul 20, 2008 | 07:48 PM
ULTIMATEORANGESS's Avatar
i would imagine DOD helps GM avoid a GG tax keeping the cost down on this car. if so i understand why its there. i wouldnt buy an auto but if it robs power id have it removed.
that BS skip shift on my GTO almost caused an accident a couple times because i couldnt put my car in the correct gear for the speed i was traveling. i had that **** removed ASAP.
Old Jul 20, 2008 | 08:43 PM
383ss's Avatar
why do half the people hat DoD so much? I don't get it...
just disable it with a tune if you don't like it
Old Jul 20, 2008 | 09:07 PM
RPM WS6's Avatar
I shouldn't have to pay for a tune on a brand new car just to get it to run the way I like.
Camaro is a muscle car, not a liberal MPG car. DOD has no place in a Camaro. It's shameful, IMO. If I can't get an LS3 + A6, then the new Camaro is useless to me.
But for those of you that don't understand why I feel this way, then good luck with your new Camaro. I'll just move on to a C6.
Old Jul 20, 2008 | 09:19 PM
68Goatboy's Avatar
lets say you werent planning on modding the engine and you really wanted an auto. would you still be pissed that your car is using less gas than it could be using?
Old Jul 20, 2008 | 09:24 PM
RPM WS6's Avatar
If I buy a V8 Camaro, I'm buying it because I want a fire breathing modern muscle car, not because I'm concerned with MPG. So in turn, if I've opted for a V8 in said car, I expect all 8 cylinders to be firing at all times when the engine is running.
I don't think that Camaro SS/Z28/whatever should ever be a conformist car. Build a base model to give people better MPG and all the Camaro style with a small, high MPG engine. But don't **** with the V8.
Old Jul 20, 2008 | 10:19 PM
TriShield's Avatar
I completely agree with you.
It's a lame thing Chrysler started to market HEMIs to people scared of fuel consumption by convincing them they were saving something. GM jumped on the bandwagon in response.
I bought a G8 GT but I will be killing DoD when I start modding it.
Old Jul 20, 2008 | 10:39 PM
BADFNZ's Avatar
I feel the same exact way. I wanted an A6 w/ paddle shifters but I don't want to have to do a cam swap and a tune just to get it to run to its full potential. If this DOD crap is in-fact on the A6, then I'll probably be looking for a C6 as well.
Old Jul 20, 2008 | 10:45 PM
HPT BANDIT's Avatar
Hate to break it to you but thats the way computer controlled cars are. Go buy your C6 A6 but your still going to have deal with torque management. If you buy a M6 you have to deal with skip shift and TM. GM knows your going to beat on it so they built in some protection.
Old Jul 20, 2008 | 10:53 PM
UltraZLS1's Avatar
Cry me a river. Go buy your automatic vette then. LOL
you are seriously not going to get it because of something you can get tuned out?
are you a spoiled little rich boy that always gets exactly what he wants or what?
Old Jul 21, 2008 | 12:06 AM
SJRTX's Avatar
can someone explain in a scientific, tangible way, how DoD harms performance? You rarely see V4 mode cruising in a truck or tahoe, and it doesnt last long. If DOD is what i think it is (displacement on demand, IE- the same as active fuel management), whats not to like about it? Hell you can barely get active fuel management to come on as it is, and only for a second. You so much as think of WOT and it wont be there, so whats the problem??
