Tuneing in michigan
Tuneing in michigan
Hi, i got a 17 m6 ss with boltons and e85. I had it tuned by a local shop, im not really impressed with them. I really dont know if theres any real good tuneing shops around me. Im going to put a wideband on soon and seen how the afr looks etc. id like to learn hp tuners my self but im really hesitant. I think it would save me money in the long run if i can learn to tune it in the street.... any oppions would be great
I'm in MI as well and went through the same thing. Had a tune by a reputable shop and was not impressed. Found a local guy and it was MUCH better. If you're interested let me know. Where are you located?
Im in macomb michigan. My buddys car (2011 ss) done by the same shop is not right either..... has a miss at idle and narrowed it down to a valve train issues which i doubt cause its fine at higher rpm, i think its a bad tune, it misses at idle after the blower setup. Therefor im thinking of learning hp tuners myself if i cant find someone.....
Im in macomb michigan. My buddys car (2011 ss) done by the same shop is not right either..... has a miss at idle and narrowed it down to a valve train issues which i doubt ca1use its fine at higher rpm, i think its a bad tune, it misses at idle after the blower setup. Therefor im thinking of learning hp tuners myself if i cant find someone.....
