Lower end build and help
So I have a 2019 camaro ss. Full bolt on and e85. Need to do heads cam and lifters then boost. I have a great shop but is expensive. Anyone know someone to help me do it myself? I'm in utah. I dont have a garage but want to do it myself. Any ideas or suggestions?
When you say low end build are you talking about the rotating assembly or are you just wanting to do H/C/boost?
The cam swap is a bit more difficult on a GEN5. You'll want to delete the AFM, and their is a cam lobe for the high pressure pump located under the manifold. To delete the AFM you'll need to plug the oil passages leading to the lifters that send oil to activate them. Also decide if you want to keep VVT or delete it, etc. Practically speaking you'll need to drop the oil pan to do a cam swap as well.
