2016 Camaro SS no crank, no start, {shift to park) on display when it's in park.
Hello all. I am new to the forum. A buddy of mine recommended this site and told me how it helped him diagnose a few problems he was having with the gen 5-6 Camaros. I am currently having an issue with my 2016 Camaro 2SS convertible not cranking over to start. When I try, a message comes up on display reading "shift to park", when the shifter is already in park position. I found a few different videos and links that explained how it's a popular issue with multiple GM vehicles with that type of part/parts. But mostly I found other models such as the Malibu, Traverse, volt, Cadillacs, etc., explaining how they temporarily fixed or bypassed it, or replaced the entire shift mechanism. I tried all the tips that I read about or saw on video such as, hitting it few times, pressing the button on shifter over and over, moving steering wheel around, slam lightly into park from drive or another gear, pump brake pedal, etc., and have had no luck getting the message "shift to park" to go away or getting the car to crank over. I found 2 different reasons for it, and what part that is needed to fix the issue. One says replace complete shifter mech for new one, and another said there's a solenoid or sensor to replace that fixes it. Either way, is there a way to bypass it for now, until I can get the right diagnosis and part/s needed to fix it. Any info at all would be greatly appreciated. Thanks
Can you try starting it in neutral? I'm not looking at a wiring diagram for it right now but on previous generations of cars you could crank them in park and neutral
