Urgent Questions
Ok, swapped the ls6 mani and used the front coolant pipe and 2 plugs for the rear. Well now the rears are leaking.... so...
Can the fuel rails be taken off with the intake still in the car?
and
Can you get to the coolant plugs in the back without taking the intake off?
Thanks alot for anyones help.
and
Location: Your girl's back door giving her the long stroke while you're at work
Yes
Possible but would be easier to yank the intake
Yes
Location: The dirty taint of the country. ...Los Angeles
I wouldn't try to get to the coolant plugs with it on. It's impossible to see so you'd have to do it all by feel that way. Plus they're soo small that if you drop one or both and it doesn't fall on the ground you'll be hating the world. Just take the intake off. It takes 5 minutes and if its leaking then you need to get your hands on one of those nice little $6 coolant line gaskets from the dealer.
....Enjoy and good luck!
Five minutes? i must be doing something wrong, without breaking the oil pressure sender and with 2 people it took me over an hour, then trying to hook everything back up. Any part number on these gaskets? Didnt know they made some for it.
Thanks for the help guys.
