General LSX Automobile Discussion Non-technical LSX related topics.
Low end power is gone
Old 11-10-2008, 05:49 PM
ls1passion's Avatar
Originally Posted by shdybrady1988
With my long tube headers my car just seems like it has no ***** at low rpm's. I know the long tube headers cause that and what not. But the only i way i can explain it is that it feels like a turbo. It seems like it is taking awhile to spool up. Anything I can do? I am working on a 9 inch so im holding off on the gears.
my car has extreme lowend power its weird i have 273s stock gears but i also have a 3100 stall. stall it and see if it makes a diffrence hopefully the stall will give it a good motivation 2 move out like mine.
Old 11-10-2008, 06:23 PM
shdybrady1988's Avatar
i checked all my spark plugs and wires. I did a port and polish to the throttle body but its a stock ls6 intake. Im guessing its just in my mind. One of those "i want more" things
Old 11-10-2008, 07:09 PM
ZMONSTER!'s Avatar
Just for conversation sake did you screw with your alternator at all? If your alternator is screwed you will loose alot of power. Ask me how I know...
Old 11-10-2008, 07:13 PM
when i did my motor mounts i moved the alternator but the feeling as always been there. also.....oh oh oh! How do you know?
Old 11-10-2008, 07:42 PM
johnLs1camaro's Avatar
yeah just make a pass in it!!
Old 11-10-2008, 07:53 PM
i want to but i believe the drag strip closed down friday. It sucks. I made up my mind i am going to go this weekend and it closed last friday.
Old 11-10-2008, 08:13 PM
71-Camaro-98's Avatar
You double/triple check all of your vacuum lines??
Old 11-10-2008, 08:27 PM
Yeah I have. See its one of those power loss that it doesnt seem like something is wrong. Like missing on a cylinder or a vaccum not connected. It just seems like my power has been takin from the bottom rpm's and moved to middle and top rpm's
Old 11-10-2008, 08:46 PM
I think it is going to be tough to see if something is actually wrong till you get it out to a track. Or find somebody close by who has a G-tech, those should be pretty accurate.
Old 11-11-2008, 02:19 PM
ls1passion's Avatar
z monster is right the ******* alternators take the explosiveness out of ur ride.
change it mine felt good some times and others it felt weak turned out 2 be the alternator.
Old 11-11-2008, 02:27 PM
LSWONGTO's Avatar
Wow I had never heard that before. Is this just for F-Bodys or all LS1/2's?
Old 11-11-2008, 03:12 PM
  #32
ls1passion's Avatar
dont know never had a ls2 but when mine started feeling weak i started thinking it was done. and then when i would let it sit 4 a long *** time take it out 4 a ride it would feel good then all of a sudden squishy as if it needed power and it was the alternator going bad. something with a cable. fixed it and then my car felt great.
Old 11-11-2008, 05:08 PM
  #33
Hamrdown's Avatar
I know exactly how you feel I felt the same thing after spending a ton of money on my exhaust I killed my low end. Then I read an artical in Popular Hotrodding magazine that explained a lot to me. Basically if yours is like mine your exhaust sytem is out of phase and the exaust tuning has changed. What worked for me was extending the collectors w/3" pipe 33" back then stepping back down to 2 1/2" pipe.Also on the Y for your Y pipe if you don't already have it then install the Flowmaster Y collector there. Available through Summit Racing/Jegs. My exhaust shop thought it was a waste of time and said I was nuts till the saw my timeslips and that I gained 2/10ths in the 1/8th mile doing this simple modification. Trust me I've spent close to $1,000 in labor to find this out. Good luck. I really think this will solve your problem.
Old 11-11-2008, 05:36 PM
  #34
well i have an x pipe my sig isnt updated
Old 11-11-2008, 05:59 PM
  #35
Hamrdown's Avatar
Even better that is what I have. I went from headers 33" w/ 3" pipe. Stepped down to 2 1/2". Then Dr. Gas x pipe to chambered mufflers. If you don't have 3" all the way back I HIGHLY recommed the collector extensions! Huge torque from low to the midrange is to be found! Most perople who have glass packs do not have to do this because the glass pack actually reacts like an extension to the collector as far as exhaust pulses are concerned. Chambered mufflers react like an opened unmuffled exhaust as far as exhaust pulses. If you have 3" all the way back I suggest bullet style mufflers or glass packs.
Old 11-11-2008, 06:21 PM
  #36
ok wait sry i got alittle confused. If i have an x pipe will it fix it if i put bullet mufflers on it. And what do you mean extensions?
Old 11-11-2008, 06:28 PM
  #37
Hamrdown's Avatar
Thats ok. If I were you and you had the x pipe I would do as follows. From the collector on the header instead of stepping down to 2 1/2" just use 3" pipe all the way for 33" long then go a head and step down to 2 1/2" pipe. Then go to x pipe then to chambered mufflers. Do you have 3" all the way back or 2 1/2"? also for sure what mufflers are you running? Bullets or chambered like magnaflow,flowmaster,or Cherry bomb extreme?
Old 11-11-2008, 06:43 PM
  #38
im not running any muffler but i will be running the dynomax bullet i was running a magnaflow with the y pipe. You know I'm not too wild about changing my exhaust for a third time lol.
Old 11-11-2008, 06:52 PM
  #39
Hamrdown's Avatar
If your not running any mufflers then that is your problem. The magnaflow will act in the same way but not to that extent. If you plan on running the bullets then do the same thing that I stated earlier just extend the collector to 24" instead of 33". Trust me I've changed my exhaust more times than I care to admit. ok over 20 times.Yeah I know. But I wanted to get it just right. I've been told that I'm my exhaust shops #1 customer. They don't even charge me now for any welding they figured I've paid enough and I have brought them so much buisness. If done right you wont have to go back any more.
Old 11-11-2008, 08:12 PM
  #40
383hatch's Avatar
It sounds like your exhaust is doing nothing for you. You need mufflers on the car for the scavenging affect. If you put a muffler back on it, it will bring the power band back down in the RPM range. Put a cutout in for the track.
