Piston Slap...
So what's the deal? Shouldn't there be a way to eliminate it?
No biggie really, the noise goes away once it's warmed up.
GC 0W30 is thicker/heavier than M1 5W30. Personally, I use M1 0W40 in both my LS1s.
http://www.upmpg.com/tech_articles/motoroil_viscosity/
I suggest you do more extensive research.
There is a range that any oil can fall in to be sold as a "30" weight. CST rating on GC 0W30 is greater than M1 5W30, hence the GC 0W30 is thicker. GC is on the thick end of a 30 weight, while M1 is on the thin end.
I spun a Bearing in my Stroker and that caused me to have Piston Slap cause the proper tolerances were no longer being met. When I pulled the Head off, I could see the marks where the Piston was slapping the Head, and it made the very distinct sound too..
Someone explain to me what you guys are calling "Piston Slap" cause I don't see it happening if everything is running good..
According to the CNBC special, it's a whole new GM. We'll have to wait til the 5th gen to see I guess...
It's the same sound that every GM 3.1L V6 has as well. They are the worst.
No there's no real way to eliminate it or even quiet it down other than oil?
It is BS though or they would have won a class action lawsuit against GM.
