What r u A4 Guys idling at??
My car idles at 800 when fully warmed up. I don't think a4's are suppose to be that high at idle in drive. I know that m6 cars are, atleast that is what i believe i seen. Just curious if there is a problem. I know that i would have a check engine light on if i was idling to high but i don't so i assume its fine?
For the mods that matter, true duals, lid, 3600 stall
500 rpm give or take 50 rpm.
Yours seem a little high with your mods (considering you don't have a massive cam or anything).
Go get a proper tune.
i idle at like 550ish in drive and 800ish in neutral.
with my ported tb(idle hole drilled too big) i idled at like 850? in drive and 1000ish in neutral and it set off an ses light hahah. then i just swapped in my stock blade and it went back to normal.
