Question for sts turbo cars
Just wondering why not bump the compression with some massaged 5.3l heads and a decent cam with some lift to achieve 400+rwhp. Just wanted to see others opinions
Plain and simple turbo's allow you room to grow should you become tired of your hp level. Wih high compression N/A engines you need to swap out heads, intake, and go to a bigger cam to increase your power level. This is also the reason why F.I. setups are the most expensive because you must take into account everything in your engine affected by the dramatic increase.
Understood .... In the case I was referring to was the remote mounted turbo is that turbo being there more effective than say a h/c set up or other f I apps
