water in oil cap
98ls1 has water in oil cap only none in oil pan thought it might b an blown headgasket but not. clean oilcap and takes a few days to show back up any sugg on what to look for![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
thanks the temp never get over 160 no matter what i do i let it run for 45 min never gite over 165 thanks again tom![Engarde](https://ls1tech.com/forums/images/smilies3/engarde.gif)
![Google](https://ls1tech.com/forums/images/smilies/google.gif)
The condensation in the oil cap is normal in winter, its just crankcase moisture that hasn't had a chance to burn off or escape. Your operating temp issue is just contributing to the buildup of moisture, fix that, take it for a long drive, and you should be good to go
![Nod](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_nod.gif)
Alot of GM vehicles exibit this condition. Nothing to worry about. Just do what was mentioned above. The best thing is to drive the car long enough to get it fully warmed up and burn all of the condensation out. If you can't do that then you will just have to live with it.
Scott
Scott
