just installed drop, now rides horrible?
I figure i already know the answer, but wanta get yal's opinions. I just put a one inch drop on my ta and now it rides really rough. Infact my mom said my wheels looked like they were wobbling. Im hoping it just needs an alignment? Its at the exhaust shop getting the pipes tucked in under it. So i'll get an alignment afterwards and hope that fixs it.
You definitely need an alignment. I put in shocks/springs, upper ball joints, new rack and new tie rod ends and they said that it was WAY off. My steering wheel was turned about 30 degrees and it didn't feel right without the alignment as well. Now it drives straighter than it ever has.
Definately need an alignment!! Lowering the car makes your camber go negative which can increase bump steer as well. I would say to find either a good repair shop or a good tire shop and get the alignment done.
did you get the HD's or revalves? HD's are valved for stock height, not drop springs.
also it may just be the higher spring rate you're feeling. it's definitely a rougher ride, and bilsteins are known to under dampen. check to make sure everything's torqued down properly too. my car drove fine for 3 days while i waited to get it aligned(had to make an appointment at a place since my car was too low for everyone's ramps)
he said he put bilsteins on it haha
I dont think i was real clear. When i said it rode rough it was do to bump steer/shaking front end. The alignment fixed it right up. Rides great and smooth now. Thanks for all the help guys i appreciate it.
yea i have the sheet here somewhere, but the angles were off pretty dramatic. Apparently just driving from the muffler shop to the tire shop (a mile or so away) loosened the lugnuts greatly. They were pulling it in...and somehow realized it and had to tighten them. Just glad its riding good again .
