LS6 Intake and Headers, what else?
Well I finally sold my old truck and now I'm going to invest (ha,ha) more money in my car. I have an LS6 manifold to go on and just ordered a set of American Racing Headers w/catted y pipe and Spohn solid motor mounts. Not much money left but what else would be a good upgrade to these parts. I will buy new plugs to go in but what about wires? Shoulld I change them now or will the oem's be O.K. I have 50,000 miles on the clock now. How about new injectors? Anything else that will not cost much as I still have to have it installed and dyno tuned. thanks in advance
Mike
yea, I plan on getting a tune. I'm getting new plugs and wires too. Chisling the ribs off the LS6 now. got new bolts for the headers, can I use the old manifold gaskets?
yes you can reuse the old header gasket, if they look worn really badly (they usually aren't) then go to a gm dealer and get oem ones. plug wires are almost a must, with the stockers mine was skipping. It wasn't enough that it ran really bad at first, but when hooked up to a scanner it had about 4-6 misses per 100 revolutions. with the MSD's it didn't have a single miss in over 10,000 revolutions on the scanner. Im assuming its because they got hot from the headers, even though they weren't touching. just food for thought.
cams?
get a TUNE most important thang to do to ur car every mod u EVER do does not see it's full potential unless there's changes made to the pcm... exhaust means more flow less restriction so that means gotta change the air/fuel n what not the so on n so on... get a tune. the right tune will get u more power n guarantee better fuel mileage... just a lil off on tune can make urt cars pcm throw the wrong amount of fuel in the system n put a black res. on ur plugs witch screws up the way they fire...
cams?
