General LSX Automobile Discussion Non-technical LSX related topics.
help!
Old Apr 30, 2009 | 07:31 PM
JTSLP559's Avatar
Default help!
ok i picked up a 01 z28 the otherday for diiirtcheap. anyways.. the guy lost the keyless entry remote for it.. however i have one from my old 99 ss, how do i make it work? iv look around cant find anything i know you can do it! help please!
Old Apr 30, 2009 | 07:55 PM
CoastieWS6's Avatar
Found this by searching! next time do a search
Matching Transmitter(s) to Your Vehicle
Each remote keyless entry transmitter is coded to prevent another transmitter from unlocking your vehicle. If a transmitter is lost or stolen, a replacement can be purchased through your dealer. Remember to bring any remaining transmitters with you when you go to your dealer. When the dealer matches the replacement transmitter to your vehicle, any remaining transmitters must also be matched. Once your dealer has coded the new transmitter, the lost transmitter will not unlock your vehicle. Each vehicle can have a maximum of four transmitters matched to it. Have each transmitter you intend to match ready for the next steps. To match transmitters to your vehicle, do the following:
1. Turn the ignition key to RUN, then to OFF. This will disarm the content theft-deterrent/alarm system (if equipped).
2. Remove the RADIO fuse. This fuse is located in the main fuse block which is located on the left side of your instrument panel. See “Fuses and Circuit Breakers” in the Index.
3. Turn the ignition key from OFF to RUN three times quickly (within five seconds). The vehicle will respond by locking the doors, unlocking the driver’s door and releasing the hatch. Your transmitter is now ready to match the vehicle. Leave the ignition in RUN.
4. Press and hold the LOCK and UNLOCK buttons on the first transmitter for 15 seconds. The vehicle will respond as in Step 3.
5. Repeat Step 4 for the remaining transmitters.
6. When you have finished matching all of your transmitters, replace the RADIO fuse.
7. Check that all transmitters work by pressing the buttons. If the transmitters don’t work, or if you’d rather not match the transmitters yourself, see your dealer
Old Apr 30, 2009 | 10:22 PM
taws6m6's Avatar
installuniversity.com has a write up on how to program additional key fobs
Old Apr 30, 2009 | 11:05 PM
JTSLP559's Avatar
well damn. im not very computer savey.. sorry, i havnt been on here in a while.
Old Apr 30, 2009 | 11:17 PM
CoastieWS6's Avatar
I wasn't trying to be an a$$. Just reminding you about the search
Old May 1, 2009 | 01:23 AM
02WS6SSZ71's Avatar
Option #2...owners manual. Spelled out in there. The dickhole dealerships will try to charge you $50 to do this and its right in the manual.
Old May 1, 2009 | 11:28 AM
JTSLP559's Avatar
oh ok sweet thanks guys
Old May 7, 2009 | 01:42 AM
JTSLP559's Avatar
Ok so i got the remote to work,however every time i lock the doors with the remote,about 2 seconds after the alarm starts going off what is going on? Any ideas?
Old May 7, 2009 | 02:20 AM
RE AND CHERYL's Avatar
Speaking as someone who makes money working on other peoples cars. If you want to pay me to do something you could have done yourself, am I supposed to refuse your money and tell you "this is easy, you can do it yourself"? GET REAL. If you bring your car to a mechanic, expect to spend money. And even if it takes 10 minutes, your still paying for at least 1/2 an hour if there are no parts involved.
Re'
Old May 7, 2009 | 10:25 AM
JTSLP559's Avatar
that didnt help at all.... i know how to do it, but my alarm keeps going off....
Old May 7, 2009 | 11:12 PM
KENS_SS_4's Avatar
You mean thanks for the replys but now I have another problem.
Try starting a new thread with the actions taken and all observed results.
Do you have the owners manual?
Download it.
Lots of good info on the alarm.
The last owner may have played with it a bit.
How good a deal?
Old May 8, 2009 | 01:41 AM
JTSLP559's Avatar
uh no,
no i dont have a owners manual.
didnt help me when i did
and 2500 bucks.
