Any videos comparing 4.10 gears?
here is two vids of me at an 1/8th mile. I run third to the about the top in the 1/8th and the top of fourth in the quarter with my current mods with out spray.
http://www.youtube.com/watch?v=2mUM7LZyY80
http://www.youtube.com/watch?v=Zkhor...eature=related
I dont have any vids of the speedo but it was the best mod I did to the car. In sixth with the 3.42 turning 2k rpms I was at 90 and now I am at 75.
If you plan on wanting to run DR's or slicks then you will need a 12 bolt or 9inch. The 10 bolts break when under stress. The way I see it is that if your ripping the tires off it then if it should be ok. So far so good for me no problems and thats with me beating/burnouts/over 50 track runs on street tires with a 2.0 60'
Also a rolling second and third gear burnout with the 75 shot of spray
I got Motive gears and the motive gear install kit
Here is a gear calculator to see the difference in mph and rpm.
http://www.f-body.org/gears/
I haven't made it to a 1/4 mile track yet this year but last year before the LTs and ORY I ran a 12.92 at 110.xx mph with me in the car too cuz Im not a little guy haha. I was topping out in 4th gear in the 1/4 mile.
No that was with the 4.10s but there are two things about my car. It dyno'd 350rwhp after the cam and before the LTs and ORY. Second is that I am about 300 lbs so im slowing the car down myself too. They say every 100lbs is about a 10th of a second. My cam is a little conservative as well so im sure you would do much better. Not trying to make excuses but I guess my car does't respond as well to mods as other people that are pulling 400 plus to the wheels cam only.
