answer on LS7 clutch kit
I have read about the LS7 clutch kit for about 4 hours on here and still never found really what I was looking for. I'm wanting to order the LS7 clutch kit # SDLS7CK from sdparts.com...all I read about is that u need a LS2 flywheel to work with the LS1 but the LS7 and LS2 flywheels are both the same right?...I mean you can bolt up an LS7 flywheel to an LS2 engine so wouldnt it be the same, just like an LS1 is no different than an LS6...so if I get that kit I'll be fine right?
I got mine for about 450$ from www.ws6store.com it came with the fly wheel and everything youll need for an install.
LS1TECH & Trucks Sponsor
The part number you wanted to order, sdls7ck, will have everything you need. No worries on what works with what. LS2-Ls7 are the same flywheel, they mount to the engine the same way as older flywheels, but the way they mount to the pressure plate is different, that's why you have to have the flywheel that goes with whatever clutch you choose. They are all interchangeable as long as you have the right flywheel. (Aside from the LS9)
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic3451_2.gif)
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
