Wheel hop. How to fix?
I was at a car show on sunday. When the show was over, every one did a burn out as they left. So I did one and got alot of wheel hop. I let off as fast as I could. How or what could I do to stop this wheel hop? Would lowering the car help? Cause I'll be lowereing it soon.
No, lowering it alone will not help. Lowering will just change your suspension geometry for the worse in combating wheel hop (If done without LCA relocation brackets).
You need to call up UMI, BMR or one of our other suspension sponsors and have them hook you up with a set of LCA's and LCA relocation brackets if you choose to lower it. That's a good first step to get your wheel hop under control.
