02 camaro ss PCM wiring
Hi,
I'm doing a swap of 02 SS and run into some trouble with PCM and engine wiring. I have 00 wiring diagram however wire colors and codes do not match up to what I have.
Did the 02 SS had special wiring scheme or its normal that GM did not follow with same wiring diagrams. To be specific, pin 9 on the red PCM connector is supposed to be dark green for fuel pump relay insted there is pink/black stripe.
Do the PCM are dirfferent between years and does someone perhaps have engine wiring diagram for the 02 Camaro SS
