Anyone pull a wheel(s) without Nitrous?
Its all about the suspension set up, torque, and sticky tires
ms4 cam
prc ls6 heads
ported 9090
full bolts ons
4000 converter
410s
weight reduction
bone stock suspension (!front sway bar)
put down around 425rwhp
pulled the tires about a foot off the ground then unloaded and spun the rest of the 60 foot..
I cut 1.63 or so 60s with that car.. I cut 1.50-1.52s with my current car with full suspension and cant lift the tires for the life of me NA.. I could change the suspension up a little and yank them all day long though..
You can lift the tires with high 1.6-low 1.7 sixty foots... you can also not lift the tires with high 1.4 sixty foots.
prc ls6 heads
ported 9090
full bolts ons
4000 converter
410s
weight reduction
I'd explain sarcasm, but I'm sure you know all about that too...
#34
nssane02, he was making a legitimate point.
what he was saying is was that you would be a fool to lift the tires without the supporting mods he was suggesting. he was adding that you need a soft suspension and sticky tires (on the front of the car) is so that when your front end slams back down, you don't crush a vertebrae and/or slide off the road.
don't be too embarrassed for calling him out in error.
#37
simple.. he's in texas. everyone knows the earth's gravitational pull is much weaker in texas. his car probably weighs a few hundred lbs less
