General LSX Automobile Discussion Non-technical LSX related topics.
wix filter
Old 11-14-2009, 12:42 PM
twitchtwice's Avatar
Originally Posted by Striker
So WIX#51522 will fit LS1's without issue?
ive been using them since i got my car a year and a half ago
Old 11-15-2009, 11:51 AM
wingman's Avatar
I use the NAPA #1522 on three LS type engines - LM7 (5.3 truck), LS1, and a GM LSX block 427. It works great on all these. The only question I have is this: NAPA calls this their Gold Filter. Why then is the body of the filter black?
Old 11-15-2009, 12:00 PM
eseibel67's Avatar
You already know the answer - it's Marketing 101. If it says "Gold" on the invoice you will pay the extra $0.50 per unit without protest.
Old 11-15-2009, 12:04 PM
wingman's Avatar
Good point.
Old 04-22-2010, 11:52 PM
SLOW 94 LT1's Avatar
Excellent! I've been wondering about this for awhile now. Wish I had found this post sooner!
Old 04-23-2010, 01:34 AM
Mumbles's Avatar
Anybody have any pictures of the longer filter (51522) mounted?
I'd like to see how low it actually sits.
Old 04-23-2010, 02:05 AM
joecar's Avatar
The K-member is still lower than the bottom of the long filter.
Old 04-25-2010, 04:35 PM
ex nihilo's Avatar
its only about half an inch or so below the oil pan you would hit other things before you hit the filter
Old 04-25-2010, 05:11 PM
sundaydriver's Avatar
The NAPA GOLD is manufactured by Wix for NAPA. Chew on that ya ankle biter!
Old 05-19-2010, 11:44 PM
LaBLKv6Z's Avatar
The long filter does hang low, heres the best angle I could get.
Old 05-29-2010, 04:06 PM
GSus's Avatar
Carquest p/n for longer wix is 85522.
Old 05-29-2010, 10:55 PM
  #32
MattxFatal's Avatar
How much more oil would be needed after a change?
Half a qt?
Old 05-30-2010, 10:31 PM
  #33
dutinsss's Avatar
i've been using the longer wix filter and i put an extra 1/4 of a quart or so when i change it.
Old 05-31-2010, 03:00 AM
  #34
Mumbles's Avatar
Thanks, gentlemen.
I actually got to see this filter in person, on my brother's SS. It does hang a bit low, but as stated previously, it still sits higher than the K-member, so there should be no troubles with hanging up on anything.
When we changed the oil in his car and upgraded to the taller WIX filter, a month or so ago, we didn't add any more than the standard 5 1/2 Quarts of Mobil 1 Synthetic. Dipstick read well above the full hash mark.
Old 05-31-2010, 08:27 AM
  #35
scatillac's Avatar
Default Filter Thread Size
+1 on the Wix 51522/NAPA 1522
Originally Posted by Anthony Williams
Their is also a high strength case version oil filter from AC that is used on the LS9 that will also fit our cars.
I'm not sure about the LS9 filter, but the filter for the LSA motor has a different thread size from all the other filters listed in this thread.
Old 12-23-2019, 11:24 PM
  #36
Rockrz's Avatar
Wix now makes the 51522xp which they say is designed for full synthetic oil and for heavy duty use.
I run this on my '13 Silverado (5.3L LS Powerplant), and also on my '09 Chevy factory V8 Colorado (5.3L LS Powerplant)
Old 11-18-2020, 02:37 PM
  #37
Dragframe's Avatar
Gen 4 motors have a different thread.
Old 11-18-2020, 03:24 PM
  #38
Rockrz's Avatar
If it's above full, that means it's a little over filled.
I thought LS engines took 6 quarts?
Both of my LS engines take 6 quarts so
Old 11-18-2020, 11:49 PM
  #39
Pontiacerator
RevGTO's Avatar
Originally Posted by Rockrz
I thought LS engines took 6 quarts? Both of my LS engines take 6 quarts so
My car takes 6 quarts with the WIX 51522 and that places the oil level right at the top of the hashmark.
Quick Reply: wix filter
