Mod's that made your car more enjoyable/fun
#46
1. 69 Camaro.
2. LS7
3. Burnout pic.
You win. I hope your happy.
#51
1. Bassani dual exhaust--these cars should be loud&this exhaust makes it happen nicely, all the way back from the cat. conv. pipes.
2. Koni 4/4's; strano SB's; adj.panhard; mod. lca's; GY GSD3; perf. alignment--all this together makes a 4th gen LS1 ****** fun to drive-FAST-
3. ram air/sealed air box--most SOTP mod so far for me. really woke up throttle response&5th/6th gear pulls. &made the exhaust scream above 3k rpm's
a short shifter is a must for 6spd cars&I'm looking forward to some brake upgrades&a tune next...
#56
I did poly motor mounts at the same time that I did full exhaust. While I loved the new roar of the duals, I was completely shocked at how well the poly motor mounts held the engine in place. It actually improved my shifter movement quite a bit.
#57
Im going to have to say the 4.10s were the most fun. its great to drive around in town now especially in 1st and 2nd, but i now have a 3600 stall on the way so we shall see how long the rear holds this mod.
the true duals were a big bonus too!
![Driving](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_driving3.gif)
#59
Just make sure you get the master install kit with all new shims and bearings/axle seals, etc. It's not 100% necessary but you might as well be better safe than sorry while your in there with everything apart. Don't forget some new fluid. Also, I went with the GM 4.10's as I've heard they hold up a little better.
