True duals?
running a full size muffler (magnaflow 4x9) and they are the lowest part. right around 2.5" of clearance.
a smaller muffler allows more clearance. i'm considering using chambered mufflers that are only 3.5" thick...will gain me another 1/2"...possibly more if i can route them differently.
taken this weekend when i tweaked it for better clearance:
car sitting on the ground....BMR lowering springs
By your theory dual 1.75" will out flow a single 3" ...
I mean 1.75 x 2 = 3.5...
Its more complicated that, your looking at volume, or diameter, no a liner dimension...
dual 2.5 may flow more... i just wanted to set the record straight, so people arent so confused... but maybe im just confusing ya more...
See, these are tucked up pretty decent. On a side note, holy cow it's rusting bad already! Car always been in Florida?
if i ran bullets i could run it down the trans tunnel more and tuck it up better, but i'd probably only gain 1/2" or so...since then the pipes will be the low part. i guess the same routing with 2.5" would gain me another 1/2"....ugh endless cycle.
i'm considering swapping the magnaflow 4x9s with some chambered mufflers that have a case diameter of 3.5"...so i'll gain that 1/2". but other things are on the $$ list first.
as for rust:
headers have been on the car since 2004
pipes have been on since 2005....and were completely submerged in ocean water when my island flooded in hurricane Wilma
mufflers have been on since early 06
