I got $2500 to spend like to hear your opinions
So im finishing up my head/cam swap and im going to have $2500 extra to spend on the car in about a month and there is a few things i would like to get for the car (02 trans am) right now i have lpp lt, ory, magnaflow, electric cutout, vig 3600, lca, relocation brakets, lid, trickflow as cats, yella terra, and custom cam 228/236 my ideas are
coil overs, torque arm, sfc, weld wheels, drag radials
built tranny a4
12 bolt or 9inch
plate kit, wheels/tires
Im not sure which would be the best route. The car is my daily driver that i like to take to the track whenever possible and race on the street hear and there. So what would you guys do?
built tranny a4
12 bolt or 9inch
You're at the point where you could do rear end...however I how about your cooling? Maybe 160 thermostat and better radiator?...upgraded brakes?...subframe connectors?...otherwise.....I'm with everyone else...rear
If you have an A4 then I deffinately wouldn't worry about the rear first. I would do (in this order):
Suspension/wheels/tires
Built Tranny/Converter
Rear end
I know plenty of guys running the stock 10-bolt with near 600 whp with full susp. and slicks. If you are going to use a transbrake, then rear for sure. Otherwise, wait untill you actually need it.
Rear end
