Fluid Capacities
Does anyone have any idea how much fluid is in the following:
M6 Trans
Rear end (including the LSD additive)
Radiator
Clutch Hydraulic System
Power Steering Fluid
Any help would be greatly appreciated. I dont have the owners manual on me as I'm sure it may be in there.
Thanks in advance.
M6 Trans
Radiator
Thanks in advance.
Location: Your girl's back door giving her the long stroke while you're at work
part of what you want
https://ls1tech.com/forums/1740921-post40.html
This may help too
http://www.pc-surgeon.net/images/cfo...te%20Fluid.pdf
This may help too
M6 Trans-4 qrts Dex III
Rear end (including the LSD additive)-2 qrts Gear Oil
Radiator- you mean the complete cooling system? If so between 3.5-4 Gallons.
Clutch Hydraulic System- Till it's full, DOT 3 or DOT 5 Brake Fluid.
Power Steering Fluid- Till it's full..grab a Quart
That should help..![Chug! Chug! Chug!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_chug.gif)
If it helps, I love your mother..
That should help..
![Secret2](https://ls1tech.com/forums/images/smilies/LS1Tech/secret.gif)
Written for an LT1 but you can take whats applicable and apply it toward your LS1
