Did Royal Purple destroy my engine? NOW WITH PICS!
Got it torn down last night. Apparently somewhere along the lines, a previous owner had at least 1 rocker arm de-bearing itself, there were like 20 needle bearings in the pan. In the pan with the bearings, were 4 or 5 1/4"x1/4" pieces of a bearing. There was only a FINE, FINE, FINE layer of metal on the bottom of the pan, and none of it came out with my 500 mile Castrol Syntec blend, the drain plug was also clean as a whistle (I havent cleaned it, and I have removed the drain plug 3 times now. Perhaps it isnt magnetic?). Hopefully I can get the caps pulled this weekend and post some pictures of the carnage, I am sure it is going to be spectacular.
The car should still move fairly well; 5.3, ls6 intake, UD pulley, longtubes, TB, ORY. Just leaving out the cam for now. Stopped at 3am last night, engine is in the k-member, underneath the car. Had some issues making my remote bleeder so I will start again tonight.
okay, tore down the engine tonight. 4 lifters dead, along with 4 lobes on the cam dead. Seems like the 1st lifter on the cam either failed or collapsed, and those are the bearings that were in the pan, along with the chunks of metal (the roller ended up crushing once the bearings went, under the stress of the patriot dual springs). IDK if the engine was over-revved or what, but it doesnt matter now. Unsure as to why the other 3 lobes died, but I am leaning towards a bad break in. I will get pictures up tomorrow.
also seems like a couple main bearings were scored pretty decently, so idk where to go from here. the rods and rod bearings looked good, but the mains where kind of iffy on the crank side (the block bearing, not the cap) of the bearing.
What did the used oil analysis show?
What did the cam look like?
What did the crank look like?
If your going to blame the oil for a failure please have somethng other than one pic than to back up your clame
Did you contact Royal Purple about this?
LS1Tech Administrator
Received 1,708 Likes
I bought a used car once, 15 hours later someone ran a stop sign and totalled it....
...I blame the oil.
...I blame the oil.
2011 tahoe
I have to disagree I have a 2011 chevy tahoe with 140,000 miles I used royal purple oil for the first time about 2 weeks ago after a few days I heard a tapping noise like a lifter tapping then by the end of the day it was very noticeable the next day straight knocking I will never use another royal purple product they are trash I would used golden state before ever using anything that even resembles their product
#32
Car is running fine now with Brian Tooley springs.
#33
Ungrounded Moderator
#34
