How to burn out in an M6
if you cant do it without bouncing off the limiter, you suck and should enver do it again. i hate when idiots think pinging it off the limiter is cool.
ARE YOU SERIOUS?!?!?!? in case you really are....
hold brake. floor gas. watch smoke. continue until satisified and/or tires burst.
Now.......who here could elaborate a little on how to take that burnout and continue it into the next gear in an m6?
Like, burning 1st > slam 2nd and keep burning > slam 3rd and keep burning??
Or am I dreaming to think this is possible without breaking stuff?
^^^^ that is exactly what I was referring to when I was asking how to burn out. I have no problem smoking them up in first, when I drop into second I get traction and take off. I was wondering how to keep it going.
youve got to power shift like a bitch... i have burnt out all the way to 4th, however when i went to 4th my clutch hated me and grinded the **** outa it. not a good idea to go past 3rd lol
1. Turn off traction control
2. Place car in gear
3. Hold down the brake with your right heel.
4. Rev car up with your right toe.
5. Drop the clutch (removing your foot completely)
6. Move left foot to brake pedal.
7. Check oil pressure
8. Check temperature
9. Check humidity
10. Check for cops
11. Check the time
12. Check for people in front of you
13. If someone is in front of you do you like them?
14. If no release left foot.
15. If yes release right foot.
16. Get out of car.
17. Bask in everyones awe as your cool factor went up 10 points.
9. Check humidity
10. Check for cops
11. Check the time
16. Get out of car.
lol!!!
#33
#34
c6 z06's are known for burning up clutches,theres a recall on them.i bet it was already bad and he was finishing it off...i would,but enough to limp it home though...
#37
Wow, this is good. . . I must take notes. . . .
Really, how to burn your tires with a MT?
Geez. . . .What's next burning tires in reverse. . . . ?
Raise RPM's - Dump the clutch, row throw some gears if you like(hold the brake if you wanna warm up your tires).
#39
http://home.myspace.com/index.cfm?fuseaction=user
here is a Vid If Me in my '94 Z M6 just Rev it Up Dump the Clutch, step on the break and let her Eat, dont worry about the Rev limiter thats what its there for!!
