Car hooks, then spins in 2nd? WTH
If I go wot off the line, my car hooks then spins when it hits 2nd. Why would the car do this? I have a a4 with junk tires. Could there be something wrong? It feels like my turbo gp did. The turbo would spool then tire spin. But I don't have a turbo....yet!
My car does the same thing sort of, but it's because I generally ease into the throttle through first to be easier on the parts and then when it shifts to 2nd it will chirp for just a second (ASR still on).
your shocks are compressing for the initial hit and then rebounding back up unloading the rear end. Get some good drag shocks that allow for rebound control. (Koni D/A)
If this were true then he would be losing traction when leaving the line with the rearend compressing. The rearend squating actually unloads the tires.
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
No you are wrong.... to an extent. yes "squating" is not the idea, but proper transfer of weight to the rear is the goal. Upon take off, your car transfers its weight to the rear, u cant argue that. after take off and under acceleration, the car then begins to "unload" the weight as the shocks rebound and redistribute the weight back forward. therefore less weight, and "load" on the back tires, causing the wheels to spin due to more hp and less load. Get some new tires and/or shocks. maybe look into your suspension setup..... something may not be set right (if you have any aftermarket susp).
LS1Tech Administrator
Received 1,727 Likes
buddys h/c stalled car is still on the 10 bolt and is spraying the car on a good tire, youd be surprised what it will take behind an a4.
I just got a set of Nitto 555's (NOT the DR's) on mine, and holy crap do those things hook! Not only could I leave the line off idle, I could also foot brake it to 1500, and barely get a chirp.
I LOVED these tires at the track, I felt like I was running DR's. And this was at street pressure with no burnout!
Tires will help alot, and don't believe everything you read, the ten bolt isn't a grenade waiting to go off, at least not behind an A4 with moderate hp levels.
These guys are right, you can do A LOT to the 10-bolt in an A4 car. I would not even consider something better for an auto car unless you go with a huge engine or big power adder. Chances are, wheel hop will kill the rear in your A4 car LONG before too much power will. If you notice this problem, then you really need to start looking at suspension work right away regardless of your tire situation.
Oh, I did just notice that you have 3.73s, these are weaker than the 2.73 or 3.23 gears so it might not last quite as long as the guys with stock rears *and* stock gears. But still, I would definitely not consider a better rear as a "must have" at your power level.
