Order of modding
To-Do list:
4l80e and stall
12 bolt
F1a procharger kit (blower, piping, cam, etc.)
Fuel system to handle 850 rwhp
Meth injection kit
408 stroker (AFR heads)
CCW SP510s (Black) 18x9.5 fronts, 18x11 rears (fuggin expensive,but that's how it goes).
Current car has everything running smooth. The weakest link in my setup that could unexpectedly fail is my 4L60e, so maybe it would be best to keep enough stashed away for the build to buy the 4L80e sooner rather than later?
Anyhow, open to opinions. Not real interested in changing my setup, just want to know the order of application. With the obvious exception that I wouldn't put the blower on the 408 until it's done and ready.
Then I would gather parts until the rest can be done at once....I have seen many guys build a boost motor and drop it in and then something happens and they can't finish the project and end up with a "built" low compression poorly matched dog.....
It seems like the order you have them in with your original post would be a good order to go about it, except you could always do the wheels first or last depending on personal preference.
Honestly I would do everything involving the motor at once unless your not sure what plan your taking, that way you only have to take **** apart once, get it tuned once etc...
Motor stuff will be the largest amount of mods done at one point most likely. Get the machine work and rotating assembly/AFRs onto the motor, get a base tune to run under it's own power, then back into my garage for the blower.The rear will go in within a month or two, so that's definitely my starting point. Once again, thanks a million guys
Build the rear end and transmission like others suggested. Then I would get the fuel system figured out, build the motor to handle the boost, the procharger, then your expensive wheels.
But yes, SFCs should be one of your first mods. Then go through your other suspension components as you see fit. adjustable panhard bar if you are lowered especially.
Yeah, definitely don't want to add weight to the front of the car, and it's doubtful you will see many real world turns where you are going to enjoy a shock tower brace, let alone notice it.
Also, thanks, I'm going to need all the luck in the world to wait patiently for resources and parts to come in
Agreed, for the most part. At least to someone who daily drives the thing, and doesn't take turns at 50 mph.
What if I milled the 317s down to 243 sized combustion chambers? Going from a 72cc to 62cc combustion chamber (if I remembered both of those chamber sizes correct, and if it's even possible, I think it is).
Would it be worth the effort to mill the heads and enjoy the bump in compression ratio/rwhp and replace things as they fail/see if it holds until the blower is ready to be purchased? I wouldn't do anything at all until I knew for sure I could cover both a rear end and transmission if they bit the dust.
I ask, as it gives me something to play with that really only costs a few hundred dollars, but potentially pays back in ***** and giggles while I wait out the time it takes to collect the money for the complete build. (Current fuel system will handle it, so I'm not worried about that).
That being said, with all the fast cars coming out, I see your concern. As always, blame Jarrod.
EDIT.....aaaannnnddd I just read up top where you said you were getting AFR heads. Like I said, I'd save the money for supercharger stuff. It is "only" a few hundred dollars, but you will need it....lol
