bad vibration noise coming from exhaust
car has bad rattling noise coming from catback sounds like metal vibrating against another piece of metal but i look under and cant find where its coming from and dont see nothing vibrating against each other.....any ideas!!
LS1Tech Administrator
Received 1,792 Likes
My '02 Z28 did this with the stock muffler at about 75k miles, random metallic rattle at certain rpms from the muffler area. I checked and re-checked the system several times and could not find any exterior points of contact. So I concluded that it had to be a baffle inside the muffler that was rattling. I replaced the muffler with an aftermarket one and the problem was solved.
this is exactly what mine is doing it sometimes does it at idle and sometimes not....but when u start to take off it rattles really bad....may have to invest in a new catback or something
That sounds exactly like how mine was. It was even worse when first starting to accelerate right after a cold start.
you sure it isnt the over axle tube touching a piece of the suspsension? I have adjusted my cat back 95 times but it does not seem that I will be able to keep it from touching 100 percent. It usually does it when taking off.
As for your issue, I've had catbacks in the past where I was also unable to get the over-the-axle pipe to not bang against the upper panhard bar, no matter how many times I adjusted it. My solution was to drill and tap new holes in the frame and move the pipe hanger enough to provide the necessary clearance.
i had a dynomax bullet that did this. i just drilled a screw in there to hold the baffle in place. problem solved. but that was just a easy fix until i redid my exhaust. maybe you can try it lol.
edit: it doesn't give any more room on the driver side, just passenger. i don't have true duals so i don't know if there are fitment issues with running over the driver side axle.
