I need something to put between my frame and y pipe
I have Pacesetter LT headers and a TSP y pipe. Under throttle it is hitting my transmission cross member. It is loud, annoying, and can trip the knock sensor. What have you all used to insulate that area? I would like to keep vibration down as much as possible, but some sort of rubber there would probably cure 90% of the problem. Will header wrap work? Or would that still vibrate like crazy?
I would but I do not have time to tear my car apart again. Not right now anyways. Maybe sometime this summer I can, but for now I need something temporary.
The heater hose isn't melting? I know the exhaust doesn't get extremely hot, but I figured it would be enough to melt a heater hose.
Hey guys,
Mufflex makes a Y-Pipe Bumpstop that normally fixes that issue. Here is a link to it on our site.
http://www.thunderracing.com/catalog...&sid=528#P3780
Let me know if I can help anymore.
Gene
Gene
Hey guys,
Gene
Gene
bought some heater hose today. will install tomorrow and post up on if it worked or not. BTW i have pacesetter LTs and TSP ORY for those running the same setup
edit: poly motor mounts too
Well that sucks that you gotta put heater hose under there so it doesnt bang. My guess would be its because of the TSP Y. I heard their Y-pipe is different. This is the same setup I was gonna go with. Kinda why I went with BBK LTs & ORY. Theyre fairly cheap & they fit great.
The TSP y pipe doesn't have much clearance on the frame on the drivers side. It doesn't hang down that far though.
If I had my choice I would have purchased the pacesetter Y instead of the TSP. However, I got everything brand new for 200$.....so I couldn't be picky.
